Can somebody double-check me?
Old Jul 25, 2007 | 05:11 PM
sixthfloorfreak's Avatar
Default Can somebody double-check me?
I'm pulling the motor out of my car to install cam, heads, HS roller rockers, oil pump, timing set, and rod bolts, as well as new headers and a FAST intake. I just need to make sure I have all the misc. hardware I need to go back together with it so I don't have to wait around on parts.
So far I have:
head bolts
oil pan gasket
timing cover gasket
water pump gaskets
front crankshaft seal
head gaskets
pipe/plugs for FAST intake install
What else am I missing? I'm very new to this, so pardon the newb question. I'm bound and determined to do this myself, but I've just never done much internal engine stuff before.
Old Jul 25, 2007 | 05:15 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Crank bolt.
And a longer, same thread, bolt to seat it prior to torquing.
Old Jul 25, 2007 | 05:20 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Oil pump o-ring if your new pump for whatever reason doesn't come with one!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jul 25, 2007 | 05:28 PM
thanks guys! TSP was supposed to send me a crank bolt but it was backordered and I forgot all about it. guess I need to holler back at them. anything else?
Old Jul 25, 2007 | 05:33 PM
sroach20's Avatar
why not poly mounts? since your pulling the engine.
Old Jul 25, 2007 | 05:35 PM
sroach20, care to post a link?
also, Matt @ SDPC, the o-ring you mentioned, is that the same one that is mentioned in the rod bolt write-up pertaining to the oil pick-up?
Old Jul 25, 2007 | 05:38 PM
sroach20's Avatar
http://www.ws6project.com/user_stor/...06c0e4012d4e69
Old Jul 25, 2007 | 06:11 PM
Not sure which link you speak of, but yes...I am sure it will be the same one. It is the only o-ring in the vacinity that needs replacing often!
__________________
Old Jul 25, 2007 | 06:14 PM
Matt, I was referring to the rod bolt install sticky toward the top of this very forum (internal engine forum). thanks again!
Old Jul 25, 2007 | 06:24 PM
Yes, same o-ring mentioned in post #5 there!
Sorry, I'm guilty of looking straight past the stickies anymore...there are just too many for me to pay attention to or read
__________________
Old Jul 25, 2007 | 06:26 PM
thanks for taking the time to help!
Old Jul 25, 2007 | 06:48 PM
shooter's Avatar
Originally Posted by orangeapeel
Crank bolt.
It's a M16 bolt the threads are 2.00 pitch and the lenght is 5 inches.
Old Jul 26, 2007 | 08:32 AM
so that's the size I want in a longer bolt, or is that the size of the stock crank bolt?
Old Jul 31, 2007 | 08:38 AM
shooter's Avatar
Nope that what you want to get the pulling on the stock bolt is the same just shorter (4 1/4 inches).
