Dyno numbers with the Cartek X-package
Old May 21, 2003 | 09:34 PM
91Formula's Avatar
Default Re: Dyno numbers with the Cartek X-package
Awesome numbers!! defidently enought power to get in the ten's. What is your race weight?
Old May 22, 2003 | 12:39 AM
BIG PD's Avatar
wow i did not know all of them things had to do with making a 10 second car. thank you for your help. all i'm am saying is that with that hp he should run 10's.
Why should it run 10's,just because u say it should big?
Theres ALOT more to runningt 10.50's than big hp.
Weather,traction,suspension,etc..
Its not as simple as U make it sound.
One things for sure BIG,Pete will run well.
Old May 22, 2003 | 04:05 AM
bspz28's Avatar
I'm not sure on the cam spec's I do know that it's a 224/228 cam. My race weight should be around the 3200 mark when I am done pulling things out and adding some lightweight parts. Thanks again everyone for the congrads. This is going to be a fun racing Season.
Old May 22, 2003 | 05:47 AM
hondakiller's Avatar
glad i live near new jersey . great numbers. i think i know where im going for my heads and cam if i dont do the cnc ls6 heads and asa cam.
Old May 22, 2003 | 10:14 AM
Big Mike's Avatar
Go Pete, Go Pete, Go Pete!!!!!!
Old May 23, 2003 | 12:55 AM
Jammer's Avatar
On the flip side of that...Cartek also just produced the head cam package for a M6 vette...with LS1 heads....and came in at 442 RWHP.
Wow!
Old May 23, 2003 | 05:17 PM
h53speed's Avatar
I think I can maybe help you with the cam specifics 224/228 .581 .588 +2(not sure) on a 113 LCA installed at 113 icl.
-Wes
Old May 24, 2003 | 08:16 PM
eb02z06's Avatar
Awesome #'s bro-no doubt at 3200lbs u should run 10's. At least 2 C5's with that package are in the 10's. I too am thinking about going the Cartek route. Do u still run the stock injectors? Does Cartek do anything with the stock intake?
Old May 25, 2003 | 03:19 AM
bspz28's Avatar
I am running 30 pounds injectors and yes they do port match the intake thanks again evryone
