Timing chain help.
Old Aug 1, 2007 | 09:28 PM
CMYZFLY's Avatar
Default Timing chain help.
OK here is the deal. I changed my cam out about a year ago. I also changed out my timing chain to a LS2 chain. I am now upgrading my cam, heads, intake, maf and throttle body to the 90/90 set up. The question I have is what timing set should I go with this time. I want to change out the gears and chain this time.Should I go with stock gears and get a LS2 timing chain again or is there something better I need to go with. Give me your help if you can. Links to product that you recommend would be great.
Thanks
Old Aug 2, 2007 | 10:13 AM
GuitsBoy's Avatar
I feel theres no sense in swapping out the gears for a new stock set. Either reuse the stock gears once again, or look into an adjustable timing set. I dont think youll wear those gears out.
Old Aug 2, 2007 | 11:09 AM
robertbartsch's Avatar
Double timing chains are very strong and not expensive.
