Comparison of Vindicator and MS4 Camshafts
Old Aug 1, 2007 | 11:25 PM
The Dragon's Avatar
Question Comparison of Vindicator and MS4 Camshafts
I think the Vindicator Cam specs are 240/244 .608/.596 112 LSA; correct me if I'm wrong
My MS4 cam is 239/242 .651/.610 111 LSA.
What would be the power difference between the two cams with ported heads, 90/90, Kooks, Corsa, full bolt-ons, etc.?
Obviously the Vindicator is larger but a MUCH lower lift with a higher LSA . . .
While I'm on the topic, what about shoving a VRX7 into a 5.7???
I'm curious about everyone's input
Old Aug 4, 2007 | 03:36 PM
JPH's Avatar
JPH
try a search.
Old Aug 5, 2007 | 03:04 PM
The Dragon's Avatar
Lightbulb
Originally Posted by JPH
try a search.
Excellent suggestion; even if you provided no valid input to this thread.
I didn't find any concrete power/band comparisons but I did find some disturbing threads about the Vindicator concerning the P/V clearance
Old Aug 25, 2007 | 07:07 AM
dadem0n's Avatar
try a search.
There is only one other thread on LS1TECH that even mentions the VRX7
Old Aug 25, 2007 | 09:13 PM
CaMaRo67RS355's Avatar
im curious as well
Old Aug 27, 2007 | 02:46 PM
The Dragon's Avatar
I was told by Ron that I would more than likely gain ~10 rwhp in the lower rpm's with "comparable" peak numbers.
Upon further investigation, I might actually lose a few ponies up top; the Vindicator just doesn't have the monster lift that the MS4 has
I don't wanna go through a cam swap just to gain ~10 rwhp in the lower regions and risk even more P/V clearance issues; to me, the ends don't justify the means
And Vice/Versa, if I already had the Vindicator I wouldn't be switching to the MS4 for similar reasons concerning different regions of the rpm
Old Aug 27, 2007 | 02:49 PM
The Dragon's Avatar
I still want Ron's heads though
Old Aug 27, 2007 | 03:00 PM
bursty's Avatar
TRex plus 2600lb RX7 =
Old Aug 27, 2007 | 03:27 PM
Asmodeus's Avatar
what heads will you be running.. and what is their flow at .600 and .650.
Old Aug 28, 2007 | 04:42 AM
venom ws7's Avatar
Ron heads with MS4 And ported fast = 500rwhp easy hehehehehe
Old Aug 28, 2007 | 04:48 AM
The Dragon's Avatar
Cool
Originally Posted by venom ws7
Ron heads with MS4 And ported fast = OVER 500rwhp easy hehehehehe
EXACTLY my thoughts BTW
Old Aug 28, 2007 | 05:14 AM
venom ws7's Avatar
I say keep the MS4 IMO Its not worth cam swap and get Either Ron heads or TSP Terminaton heads mill them and enjoy 500+rwhp H/C/I M6 car.
