How do you guys feel about this cam?
I am most likely going to do this with a cam... probably the 230/238... what do you guys think.
Thanks a lot for all of the feedback guys... you guys are awesome, and have made the dicision making process a lot easier!!
Would I have any problems like PVC, or any other valvetrain or engine problems with a set of 5.3's from Absolute.. not because of their heads but because of this cam.
How will the low end be and the midrange with heads on this 230/238 cam?
Thanks!!!
Mike
They are about the same price and they are both in the range that I am looking for. What valves are better, Manley or Ferrea?
Also agree w/Cal........
Good luck!
Also 4.56 gears is the smallest gears to use a 488 closer if you have a 12 bolt. also u must change pushrods and valve springs and lt headers and the most important mod your computer, ed wright at fast chip. headwork also will make a big difference with that cam, i have a cam almost the same size email me if you have questions nosman@attbi.com
They will be unmilled (I think) 5.3's w/ dual 987's Titanium Retainers, and Manley pushrods.
I think that 4.10's will do the trick.. and if not.. oh well, it is not a strip car anyway... it will be ok on the low end with 4.10's.
