LS6 Cam Dyno #s
Old May 20, 2003 | 08:27 PM
2xLS1's Avatar
Default LS6 Cam Dyno #s
I installed a 02 LS6 cam in a buddy's car and he finally dynoed it. This was his first dyno, so I don't have any before numbers. Here are the mods on the car:
02 WS6 M6
Whisper Lid
FTRA
FLPs w/ cats installed.
ASP Pulley
Corsa Cat-back
02 LS6 cam/springs
STD:
386 RWHP
375 RWTQ
SAE:
378 RWHP
367 RWTQ
On a side note according to Ed Wright, STD numbers will vary less with changing weather conditions.
Old May 20, 2003 | 09:36 PM
CRASH 02's Avatar
Default Re: LS6 Cam Dyno #s
Must be nice to be pushing 380hp to the wheels and still have the stock idle. I wonder how much it would have made if he would have ran the off road pipes?
Old May 20, 2003 | 09:39 PM
02 SOM SS's Avatar
Awesome man. I am very pleased with mine. I picked up 2 tenths and 2 MPH and even with the muffler off you can not hear any lope.
Old May 21, 2003 | 08:56 AM
KraZy's Avatar
Damn!!
Is that with stock LS1 heads?!
Old May 21, 2003 | 10:00 AM
CRASH 02's Avatar
Yes stock LS1 heads.
Old May 21, 2003 | 12:35 PM
finalymodded's Avatar
after a tune on the dyno?
Old May 21, 2003 | 12:54 PM
WS6snake-eater's Avatar
Any tuning done yet?
Old May 21, 2003 | 02:07 PM
2xLS1's Avatar
No tuning. I listed all the mods on the car, period.
Old May 21, 2003 | 03:17 PM
King02SS's Avatar
Those are some very impressive numbers. Did you happen to run into any unique problems on the install? I was planning on putting one of these cams in my SS sometime this summer. I might have the install done. I really want to do it myself but I'm kinda nervous about breaking into an engine with less than 7,000 miles on it. Just kinda curious if there are any suprises to expect on it.
Old May 21, 2003 | 03:36 PM
LOL! the hardest part if it is your first time to do something like this, is the cuts/bruises/scratches. My first time to take it apart and replace lifter, pushrods, springs and cam took 2 days. The next time I took it apart and replaced the head gasket because I put it in upside down on the driver's side took half a day.
Old May 21, 2003 | 07:12 PM
2xLS1's Avatar
No. I've done 8 cam installs so they are getting pretty routine. Out of all those cars, I've only had one car that 3 of the lifters wouldn't stay up on and I had to use pen magnets. Leave the pushrods in until after you spin the cam and watch them for a few minutes and you'll know if any lifters are dropping.
Old May 21, 2003 | 08:11 PM
ArcticSS's Avatar
what size pushrods did he use. arent you supposed to use longer ones? and did he also get the new timing chain and cover and all that stuff?
Old May 21, 2003 | 09:43 PM
2xLS1's Avatar
Stock pushrods. Someone needs to make a sticky thread that you don't need longer pushrods for this cam. Car only had 13K miles on it so I didn't replace the chain.
Old May 21, 2003 | 10:46 PM
CAT3's Avatar
Restricted User
Nice numbers and good info. I never changed a cam in a LS1 and would like to know do you have to take the lifters out a certain way or what? Thought I sen a post about a new tool to leave them in, but cant recall where? TIA. Charlie.
Old May 22, 2003 | 11:21 AM
2000LS1Z28's Avatar
You won't hear any lope with the '02 LS6 Cam since it has an LSA of 117.
Mike
Old May 22, 2003 | 01:39 PM
Hunter98TA's Avatar
I don't get it. I have a COMPLETE 2002 LS6 engine (read that, LS6 heads) and after a Cartek tune only put down 367HP 358TQ. MAC Headers are the only other mods.
Hard to believe that my stock pully and Flowmaster muffler is robbing that much power.
Matt Sr.
Old May 22, 2003 | 05:30 PM
ArcticSS's Avatar
thats weird because over in SDPC--------------->
they say that you need longer pushrods. but if you did it and there are no problems, then thats all the better. no extra money to spend. more for this
Old May 22, 2003 | 07:47 PM
Unusual T/A's Avatar
Matt Sr.
Change it and the headers and see what ya get!
Old May 23, 2003 | 04:33 PM
How long does it take you guys to do this cam and spring sway? Any how-to's?
Old May 23, 2003 | 04:42 PM
niphilli's Avatar
Great Results!
Matt Sr.
A lot of people do not realise that the LS-6 casting head really does not give any advantage over the LS-1 casting head in stock cube small-cam applications. I think if you switched to LTs and used a pulley you would see similar results.
I hope people take note of this and start using some of the smaller grinds for stock head applications. I think for a stock headed LS-x a small cam will get you 90% of what the big cam guys are getting.
-Nick
