Heads and Cam Question?
What length pushrods will i need?
What head gasket will be good?
Will this require flycutting?
Would it be better to run these heads with MS3?
I will also have 4.10 gears at the time to help getting it moving.
Please let me know what you guess think. thanks
Jon at TSP has been very helpful when I PM him about any of this stuff.
The larger valves will require you to cut your pistons. If you'd like to cut the pistons you can run some extra compression & run even larger valves.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
The MS4 With those heads will be an awesome combo if you did the flycutting.
Good luck man.
