used cam
Old Aug 6, 2007 | 08:36 PM
garrett98sscamaro's Avatar
Default used cam
Hi i have a 1998 ss camaro and i have been thinking about putting in a new cam (ms4 with ls6 ported and polished heads) but that would cost me around 3 grand. but my buddy at work has said he would sell me his old cam, pushrod, and springs for threehundred and i was just wondering if it would be a bad idea to put a used cam in my car
Old Aug 6, 2007 | 08:54 PM
Mike454SS's Avatar
I've seen a lot of people do it and have no issues at all, I haven't done it myself...but if the price is right, and it's a cam that you like...make sure it's clean and has no damage (just normal surface finish that roller lifters put on cams) and you're probably all set...if you really want, you could take it to a local shop and ask them to make sure it's ok before you put it in...
Old Aug 6, 2007 | 09:31 PM
EndlessSummer85's Avatar
Just clean the cam real good with some brake cleaner and put new oil on it when you install it, and you should be fine. As long as the car that it came out of had no problems you should be straight. I just bought a used cam and that's all I'm gonna do.
Old Aug 6, 2007 | 09:35 PM
ok thanks, do you think i should change out the cam bearings? i only have 44,000 on the car
Old Aug 6, 2007 | 09:44 PM
02 T/A 984's Avatar
The only thing that i would really be concerned about would be the pushrods and valvesprings more than i would the cam i say if it all looks in good shape go for it and i also recomend what mike454ss said take it to a shop and have them inspect it.......good luck
Old Aug 6, 2007 | 09:52 PM
therealthatguy's Avatar
i bought a used thunder racing cam, and a used set of patriot 918's off a friend of mine and theyve been in my Z for 3 months now with no problems....definitley a less expensive way to go....
Old Aug 6, 2007 | 11:54 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I would only buy used items from a trusted friend. Anything else is a crapshoot. You may get the best part in the world, or you may get fucked. How much is your time and money worth?
Old Aug 7, 2007 | 03:59 AM
Mr. Bungle's Avatar
Take it somewhere and have it looked at. I would say the pushrods would be ok but I would probably just go ahead and get some new springs depending on how many miles they have on them.
Old Aug 7, 2007 | 08:39 AM
Patrick G's Avatar
LS1 Tech Administrator
Moved from advanced tech section.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 7, 2007 | 09:21 AM
radkon's Avatar
Do you know the specs of the cam?
Do you know how many miles are on the springs?
Does the cam have any pitting or rust on any of the lobes?
If you can answer these questions you'll probably be OK.
Old Aug 7, 2007 | 09:08 PM
Mike454SS's Avatar
If I were in your shoes, I wouldn't touch the cam bearings...try to find someone you know who's worked inside of engines more than you have and ask them to help you check them out when the cam comes out...but every cam I've ever swapped in an LT1 or LS1, I've always had more like 120K miles on the engine, and the cam bearings were all fine, so I always left them alone...be careful not to bang them up sliding the old cam out and the new cam in, and be careful that you go through the first one(front of the block) straight as an arrow (so you don't bind the cam up in it as that will cause damage) with the old one on the way out and with the new one on the way in, and make sure everything is IMPECCABLY clean and covered in fresh oil (same oil you plan to run the engine on) and you should be just fine.
ALWAYS clean around all the gasket surfaces and sealing edges before removing parts...lots of people do heads/cam swaps and lose the engine right away...most of the time it's because some dirt got in there somehow or another.
Old Aug 7, 2007 | 09:19 PM
GT Griller's Avatar
bought 2 sets of cam and springs on here in the forsale section and they both have performed flawlessly for me and my buddy........my cam and springs have been in for about 9 months now.
