cam card help
Old Aug 8, 2007 | 04:41 PM
jeejee's Avatar
Default cam card help
i'm not used to how these cams are being measured
but at how many degrees btdc / atdc does this one SHOULD have full lift ??
the 119 deg lobe sep agle doesn't nessesarely mean it is allso at 119 degrees max lift i would think..
i normally install a cam by the max lift at xxx crank angle
or IS the 119 the correct value i'm looking for ??
thanks..
Old Aug 8, 2007 | 08:21 PM
JPH's Avatar
JPH
thanks..
pay close attention to the specs @.006, and make sure int/exh valves are opening and closing at there specifed degrees.
Old Aug 9, 2007 | 03:05 AM
jeejee's Avatar
yes i know. but i would prefer to use the max lift at xx deg crank rot. , as the exact opening at xx deg. could allso be somewhat affected in my eyes due to other factors, and max lift not so much.
as otherwise i would need to be sure to allso have the 0.006 clearance to measure correctly, and with max lift that is not ness. i could even run clearanced tappets, that would still not affect my reading
Old Aug 16, 2007 | 03:42 PM
jeejee's Avatar
anybody else ??
