Are all 98 and up aluminum blocks the same?
Old Aug 8, 2007 | 07:39 PM
bugmenot1's Avatar
Default Are all 98 and up aluminum blocks the same?
question in title. I heard that some earlier ls1's had small problems. Don't know if this is correct. Anyone have any problems with earlier ls1 blocks or are they all the same.
Old Aug 8, 2007 | 07:53 PM
Thule's Avatar
i changed to 99 block..
Old Aug 8, 2007 | 08:01 PM
DrkPhx's Avatar
I assume you're talking about the LS1 block. The 97-98 blocks are different than the 99-up LS1 blocks. The main difference is the oil galleys with 99-up having the improved revision and the 98's can't be bored as much as the 99-up blocks. With that said, the 97-98 blocks are solid blocks and usually don't have piston slap like the later years.
Old Aug 8, 2007 | 08:14 PM
socmguy's Avatar
Restricted User
I believe in '01-'02 they began using ls6 blocks.
Old Aug 8, 2007 | 08:29 PM
bugmenot1's Avatar
Can I assume the 99-up blocks are stronger then?
In general how much horsepower can the blocks take before cracking?
97-98 hp max???
99-up hp max???
Old Aug 8, 2007 | 08:37 PM
mypoorLS1's Avatar
I don't think one is stonger than another. the newer ones have better oiling. Which is better on a high HP motor
Old Aug 8, 2007 | 10:19 PM
95 Z28's Avatar
only a select few got them.
Old Aug 8, 2007 | 11:07 PM
nofearracing28's Avatar
how do you tell which ones got them
Old Aug 9, 2007 | 12:01 AM
Evans752's Avatar
Some of the 01 got the LS6 Block and about half of the 02 got them (1168) LS6 block Last 4 digits located on the rear of block on drivers side.
Old Aug 9, 2007 | 12:24 AM
SoCal01z28's Avatar
how much better? i just killed my 01 motor, so im building up and getting ready to drop in a 98 block that i had laying around.....
