She Blew!!!!
Old Aug 12, 2007 | 09:46 PM
Trev_SS's Avatar
**** what else guys i need to talk to tsp
Old Aug 12, 2007 | 10:01 PM
theblur98ss's Avatar
Could be a head gasket? I think it could be something simple. I'd pull the head back off and see what it looks like. Did you remember to put the both the plugs back in the head?
Old Aug 12, 2007 | 10:15 PM
Trev_SS's Avatar
Yes i belive both plugs are back in the head i do hope so, i just hope i didn't ruin my ******* car because of something stupid. i bought this car at 18 brand new, with all the slp options it was my dream car. this car only has 17000 miles on it, very well taken care of car with zero scratches in it, and a perfect interior for five years old. I am just sick i guess i will not know anything untill i tear it back down.
Old Aug 12, 2007 | 10:23 PM
98Camarod's Avatar
Just hope that it IS a plug leaking and not anything else
Old Aug 12, 2007 | 10:26 PM
Trev_SS's Avatar
yea i know if so i am going to pist from hell, I am going to take back off both heads on the car and go on head and clean the **** out of all the head bolts. clean the block if i see any type of cracks i think that i am going to throw the stock heads and cam back in and take it to gm and have my extended warranty take care of it.
Old Aug 12, 2007 | 10:38 PM
98Camarod's Avatar
lol, good idea if the block is cracked.
Old Aug 12, 2007 | 10:55 PM
Trev_SS's Avatar
Do you think that they will bitch about the block being cracked if the cars has headers and true duals i mean i would just tell them that the car has a coolant leak and needs fixed but i do not think they would like that at all
Old Aug 12, 2007 | 11:01 PM
98Camarod's Avatar
I honestly do not know.
Old Aug 12, 2007 | 11:16 PM
mypoorLS1's Avatar
Not trying to be nasty, but everyone has been talking about this for about 12 hrs now. GM isn't going to fix it. They don't want to fix things they should be held responsible for. I would have had this thing torn apart as soon as it got home. I'm much better about ripping into things than I am putting them back together. Go see what the problem really is before you have a heart attack worrying about it.
Old Aug 13, 2007 | 03:21 AM
bsf's Avatar
bsf
That is bullshit. If you ruined your block, man up and take responsibility for your negligence/shoddy workmanship. Integrity, ever heard of it?
P.S.
By any chance can you put together a proper sentence?
Old Aug 13, 2007 | 12:15 PM
ramairracer's Avatar
we had the same problem on my buddies Ta 6.0 block ls6 heads, it leaked its *** off, and we thought we were screwed, but later since i work at the dealer i found some pills you throw into the radiator and they seal it, his was leaking from the rear of the head, on the drivers side, but it has yet to leak, ill try to get u a part number later
Old Aug 13, 2007 | 01:27 PM
  #32
Specialized's Avatar
Terrible advice, I would never advise someone to bandaid a serious problem like this. Just find out what the problem is and fix it.
Old Aug 13, 2007 | 03:00 PM
  #33
BlueStreak362's Avatar
i dont know much about cracked blocks but, wouldnt the block have tweaked and thrown off the geometry/spec of all the internals? which would make it run horribly if it all. Again, really not sure but if you think about it makes sense.
Old Aug 13, 2007 | 03:03 PM
  #34
Trev_SS's Avatar
yea i think your right if i would have cracked the block then my car wouldn't run at all period, the car will start up and run but only for a little bit because then it gets way to hot to run
Old Aug 13, 2007 | 03:12 PM
  #35
Tainted's Avatar
yall get off his ***, this aint 4th grade english class with mrs. chokesondick jesus.
Take off the manifold, wipe everything down GOOD. run your fingers over every surface and feel for flaws, theres actually a paint you can buy that will make cracks show up. maybe try that. before you go planning another motor, eliminate the small things first. no sense in dropped 5k into a new motor when its a $50 fix
Old Aug 13, 2007 | 04:19 PM
  #36
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Shoot me a pm if you need a hand with anything. Your car would run with a cracked block depending on where it is, but if you are seeing oil it is more than likely blowing by from the bottom end and possibly out of a crack. But then again it could be something really easy.
Old Aug 13, 2007 | 06:31 PM
  #37
1FSTLS1's Avatar
No expert here but if you cleaned everything up good and unhooked the coil packs and had a friend crank the motor over would you be able to see any fluids come from a crack? 2nd idea. Buy a peice of **** car to drive around and pull your motor out make re-build it make it bad *** and take your time. Sorry for your loss.
Old Aug 13, 2007 | 07:38 PM
  #38
since my advice is out the window that could have been a temp. fix at least, but maybe the the coolant crossover pipes under the intake did it. these leak on vettes if they are reused, good luck man, youll certanily need it!
Old Aug 13, 2007 | 10:50 PM
  #39
The PAT WS6's Avatar
P.S.
Shut the **** up, seriously if a man pays 2k for a warranty **** gm. them techs have nothin else better to do that stick their thumb up their *** at the dealerships...
trev u did NOT blow ur motor, pull the intake off and u will find ur problem. we should of cleaned ur heads to the fullest im sorry i was not there 100% of the way man, but call me if u need a hand i can help u tomrw since we are both off to fix it.
Old Aug 14, 2007 | 06:17 AM
  #40
striker754's Avatar
yep fraud is cool. if you can't afford to break stuff or do the job right, don't do it at all.
