LS6 heads...whats the casting # and how to differentiate from ls1
i tried a search it wasnt workin for me :-\....
and correct me if im wrong but an ls6 block is also a darker shade right..if i was lookin for that also....???
241 castings are LS1 heads from generally 2001-2004 years, maybe some late 2000 models. 241s are not LS6 heads.
243 = LS6 heads.
A dirty block is a darker shade.. an LS6 block looks exactly the same as an LS1 block.. you can only tell by casting numbers on the back.. and the LS6 and LS1 block are virtually identical in every way.. the LS6 has better bay to bay breathing.. but structurally they are the same, the LS1 is even a bit stronger.
We can sell you brand new GM 243 castings for $395.00 per pair bare or $425.00 assembled with oem non-sodium valves.
