550 rwhp? help!!!!!
is there a cam, head, intake combo that i can get 550-600 rwhp. or real close to it? i would rather not use nitrous, i want it to be a n/a car. please help.
550+ to the ground... You're going to need more cubes or a power adder. No way around it really unless you want a totally unstreetable race car. But the money it would take to make an N/A 346 to make that power would easily get you into a stroker setup.
You can make 550-600 rwhp with stock cubes but it's going to require a completely different setup than most people on the board run. First, you'll need to turn LOTS of rpm so be prepared to build an 8000+ rpm short block. Next, heads. Any of the premium aftermarket heads will do. Compression: Think 12.0:1 minimum. Intake manifold: Sheet metal intake with cross section and runner length tuned for your high rpm level. Cam. Solid roller: Fairly big.
Basically, you take a setup like Joe Huneycutt from SixSpeeds Inc runs, but only with fewer cubes. If he can make over 700 rwhp with 400 cubes, 600 with 346 is going to be achievable...but not cheap.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
lol, it's kinda funny when people just throw out a number.
Have you ever driven a 550 rwhp N/A street car? Because if not, I don't think you really know what it is that you're asking.
ok so what would you recomend if i was looking for a streetable car, with great power. i would like a set up with a consistant powerband. something that will **** and get. and if possible mid-high 10's.
actually i have been in a car that puts 550 to the ground and it was a RUSH.
My point was N/A + 550whp + streetable + stock cubes is an extremely tall order. If that's even possible (would require a healthy roller cam which won't have good street manners) it will cost a lot and you better know what you are doing.
If streetable is your primary consideration an FI setup would probably better suit you. A blown or turboed 550rwhp will be a LOT more streetable than N/A.
im running a built a4, 3000 stall.
and yeah i just noticed a typo......mid-high 10's.
stock ss runs low 12's. sorry alittle tired here.
4000 stall
ms4 cam (and everything that goes along with a cam swap)
maybe some ls6 ported heads (to save ya some money)
suspension work
big tire
and a rear end b/c your 10 bolt wont hold up much
oh yeah and since when do stock ss' run low 12's?
408 ci
with l92 with port work or ls7 heads
cam in the 248/250 ish druation with around .6** lift
ported l76 or sheetmetal intake
and the associated mods to make it handle well.
will be streetable and put you in your range
you can dig into a longblock with that kind of setup for a good price,
