valve train noise
Old May 24, 2003 | 06:35 PM
lrmneil's Avatar
Default valve train noise
I just installed a tr220/220/561/561,114 with 941 springs and the damm thing sounds like a sewing machine, what can I do to correct this?
Old May 24, 2003 | 07:15 PM
lrmneil's Avatar
Default Re: valve train noise
come on guys I cant be the only one with these problems
Old May 24, 2003 | 08:07 PM
TaTommyWS6's Avatar
Do a search...
Most people with a relatively high lift cam say their car sounds like a sewing machine. I don't think there is anything you can do to "fix" it since it is not broken! Just the way a higher lift cam sounds!
Tommy
Old May 24, 2003 | 11:52 PM
99taws6's Avatar
Welcome to the world of aluminum block/heads with high lift cams.......
Old May 25, 2003 | 06:32 AM
lrmneil's Avatar
Cool as long as its fine, I guess I will just get some long tubes and drown out the noise.
Old May 25, 2003 | 06:51 AM
Slowhawk's Avatar
LS1Tech Sponsor
I ran a tr 220 and had no noise in the valvetrain.Now I run a tr224 with no noise.I would check pushrod length to make sure there is atleast .050 collapse of the lifter.
Could be the 941's though.I've never run them.
Old May 25, 2003 | 06:53 AM
sross's Avatar
Mine was the oil pump o-ring...
Old May 25, 2003 | 06:59 AM
Gary98Z's Avatar
The yella terras help to quite down the valve train.
Old May 25, 2003 | 07:17 AM
malibu350's Avatar
Just the way it is....the only thing that you can do is tune it to where it sounds like a very good running sewing machine...... :p
