what is the best oil pump??
Old Aug 19, 2007 | 05:50 PM
Asmodeus's Avatar
I bought SDPC's high volume oil pump.
Old Aug 19, 2007 | 07:46 PM
SmallTires's Avatar
Originally Posted by rpmauto
i saw on speed incs website that if you use the slp pump with a asp balancer you have to modify the balancer, is this right. Does the melling pump matter what balancer you use??
Well considering this is what is on my car that I just drove about an hour ago with no modification to either. No...
Old Aug 19, 2007 | 08:17 PM
john563's Avatar
Originally Posted by bad6as
for the mellings pump users.
when you got it did you have the extra porting done?
also how does a stock ls6 pump comapre to a ported ls6 pump comared to the non ported mellings
Good question? Do any of you melling owners want to comment.I'm curious myself
Old Aug 19, 2007 | 10:09 PM
1CAMWNDR's Avatar
Mine is not ported nor is it in the car yet. The +10 psi spring is in the pump, but they include a stock psi spring if you want to use it instead. The +15% volume is quoted as non-ported. I am not going to bother porting mine.
Old Aug 20, 2007 | 10:18 AM
bad6as's Avatar
so when you buy the pump it all ready has a 15% increase in volume and has the 10psi spring in it. but you can have more porting done and you could install the stock psi spring
Old Aug 20, 2007 | 10:31 AM
500 HORS's Avatar
Mellings=time tested. I believe that only extereme applications require a high volume/performance pump - they can actually rob a bit of power...
Old Aug 20, 2007 | 11:18 AM
Gauge's Avatar
11Second Club
Take a few ponies from my motor. I won't complain as long as I don't lose oil pressure.
Old Aug 20, 2007 | 01:50 PM
FL_BILL's Avatar
I called Lingenfelter's on this issue. They told me that you only needed a ported oil pump when you ran additional clearance on the crank bearings. Otherwise, you only needed a stock type oil pump, including a standard Mellings.
Old Aug 20, 2007 | 05:09 PM
litle88's Avatar
I love the higher psi, at least I know my ls1 is getting lubed.
No complaints here, dont see how it robs power but if it does I still clocked 393hp on the mustang dyno.
Old Aug 21, 2007 | 06:23 AM
Formulated's Avatar
I can agree with that statement. I'm not sure why there's so much hype about replacing pumps on otherwise stock engines. The only reason I can see for doing it is to run lighter weight oil, because you will need the extra flow capacity to make up the pressure difference. I might just try that myself.
Old Aug 21, 2007 | 03:02 PM
spy2520's Avatar
i heard the slp is a melling clearanced for a double-roller timing set. i actually believe speed inc. said this in the sponsor sales section.
Old Aug 21, 2007 | 03:43 PM
  #32
bad6as's Avatar
so i could save $50 and get a stock ls6 pump and be safe
Old Aug 21, 2007 | 04:09 PM
  #33
5_02ls1's Avatar
i used a stock ls2 pump its the same as an ls6 and gained 15psi of pressure over the stock 98 pump.....
Old Aug 22, 2007 | 09:55 AM
  #34
Bluesteel's Avatar
Where can you buy the melling???
Old Aug 22, 2007 | 10:23 AM
  #35
2001 Pewter WS6's Avatar
Restricted User
Mellings come with two different springs, red and blue. The red one will give higher pressure and is designed to be used with an external oil cooler or external oil filter. The blue spring will still give the extra volume but more stock pressure. Take it from me, I have the red spring in and will be changing it to the blue one. I have 70psi at idle which is way too much pressure and it will peg at WOT. Too much pressure at WOT can blow the oil filter off.
Old Aug 22, 2007 | 02:45 PM
  #36
gun5l1ng3r's Avatar
I like how melling does some R&D and comes up with a solution for more serious (external oil cooler/filter) motors.
I have a stock 98 pump now, and I hope it lives, but when it does die, I will buy a Melling w/ the blue spring...
Old Aug 22, 2007 | 11:29 PM
  #37
99DWPTA's Avatar
anyone run katech oil pumps?
Old Oct 15, 2007 | 05:59 PM
  #38
bad6as's Avatar
sorry to bring this back up but,
i still dont know what pump to use
stock ls6
ported ls6 from tsp
or the mellings part number 156-10296 from thunder racing (non ported)
im going to change the pump when i do my cam swap and the car might see some n20 later on. i think im leaning towards the melling non ported for 148.99.
Old Oct 15, 2007 | 06:56 PM
  #39
JScamaro's Avatar
stock ls6
ported ls6 from tsp
Just get the standard melling oil pump. Plenty of people run them without issues and they have a great price.
Old Oct 15, 2007 | 10:04 PM
  #40
Websy21's Avatar
Or get the standard LS6, ported if you want to spend the extra money. I got the SLP pump and SLP double roller chain and I have great pressure. If money not an issue I think you'll be fine with either the melling or LS6 ported preferably or unported. Many people run the standard LS6 unported as long as your setup isn't too extreme you'll be fine. Pick, order, install and enjoy, quit worrying
