Engine Problems: Low Compression in 3 Cylinders, Eats oil
Old Aug 18, 2007 | 01:56 PM
Jolly^Roger's Avatar
Question Engine Problems: Low Compression in 3 Cylinders, Eats oil
I have a 98 z28 that I've owned for the past 5 years or so. Roughly 3 years ago, I had some serious mods done and until now everything has been ok. Just recently though on regular oil change, my oil was down to 1.5 quarts at 2500 miles. I had a compression test performed and 3 cylinders are extremely low. The car runs, but eats oil like no other.
As far as engine mods go, I had a custom grind ( 232/232 112 LSA w/ relatively high lift ) installed with new springs, retainers, and pushrods 3 years back. I installed JetHot long tubes and an offroad Ypipe about a year prior and have a long list of various other and unrelated mods.
My regular mechanic suggested either a rebuild or new engine. My questions are ...
Any ideas as to what the exact the problem is? Piston rings?
What kind of cost can I expect in a rebuild or what parts can I expect to be replaced? I expect that this number can vary significantly, but any rough guesstimates would be appreciated. My regular mechanic does not perform rebuilds so if anyone knows of a good shop that performs this type of work regularly in or near Boise, ID, please let me know.
Budget will be an issue and I assume a rebuild will be cheaper than purchasing a long-block and having it installed. However, how cheap can I find a new and nearly stock LS1? Visiting some of the sponsor sites I've been seeing prices in the $5000 range for engines alone. Are there any better prices or sources out there?
Thanks in advance for your time and help. It's greatly appreciated.
Sean
Old Aug 18, 2007 | 09:54 PM
theblur98ss's Avatar
How many miles are on it? You could always watch the classifieds on here. there are always used stock motors pretty resonable on there.
Old Aug 19, 2007 | 03:10 PM
Just under 90,000.
