Goodbye piston...carnage pictures inside...
Old Aug 20, 2007 | 04:53 PM
BQTransAm's Avatar
Originally Posted by TransAm578
I am not sure what I am going to build. I don't have any money to throw at it now, so it will probably be next season before it runs again.
This might be a dumb question, but could I do a 408 block and reuse the trick flow heads and top end that I have now? Would the heads even line up to fit? I know they wouldn't flow as well, but it would be better than another 346.
They will line up, but you would be better off selling them and the cam and doing the 225s and a bigger cam on a 408. Your cam and heads would work well on a 370, and with a FAST 90. TSP has them on sale.
Old Aug 20, 2007 | 05:01 PM
TransAm578's Avatar
What up Bob? That might be a good idea. There are a ton of options out there, and unfortunatley, I have a while to decide.
Old Aug 20, 2007 | 05:30 PM
BQTransAm's Avatar
Yes there are. Sucks that thing let go so soon. Who helped you pull it apart?
Old Aug 20, 2007 | 05:36 PM
TransAm578's Avatar
Nathan, Michael, and I did it.
Old Aug 20, 2007 | 10:35 PM
Pipelayaz's Avatar
Thats pretty fucked up, I thought your head would be all chewed up. Good excuse for a 408.
Old Aug 20, 2007 | 11:28 PM
H82BU's Avatar
And I'm ready to do the rest whenever you are....I love this kind of ****.
Although I think we each lost 5lbs in sweat....
lol... that damn rear bolt....next time I'm bringin a breaker bar...lol
Either way I had fun and I would help anytime.
Old Aug 20, 2007 | 11:42 PM
TransAm578's Avatar
Wow...thanks for posting those pics...hahaha...we will get the rest of the project done soon...maybe this weekend?
I appreciate the help!
Old Aug 20, 2007 | 11:58 PM
H82BU's Avatar
standing on the engine = happy blake, bc there is no leaning on the fender...lol...not to mention better leverage
im down for some more work this weekend
Old Aug 21, 2007 | 12:25 AM
LS1Silverado05's Avatar
Just saw the Mizzou shorts..didnt even notice you guys are in the MO. Im in JC..I was just in STL Saturday. No wonder you guys are sweaty...its been hot as hell lately huh.
Old Aug 21, 2007 | 07:04 AM
TransAm578's Avatar
It has been miserable! I can't wait for a break from the heat and humidity.
Old Aug 21, 2007 | 08:38 AM
3stgstocker's Avatar
mine done it on nitrous been running it for 2 years just decided to give up. only difference was that my whole cylinder was gone and the piston
Old Aug 21, 2007 | 08:40 AM
  #32
5.3LJimmy's Avatar
Looks alot like mine.
Old Aug 21, 2007 | 09:43 AM
  #33
briannutter's Avatar
Default o.e. cast piston?
o.e. cast piston? I noted .030 over... what kind is it? Also, what happened to 1 exploded piston is on the way to happening on the other 7. look them over closely for signs of the top land cracking, oil ring groove cracking, or pin boss tower cracking. You may want to have them magnefluxed.
Old Aug 21, 2007 | 10:01 AM
  #34
Black FormulaLs1's Avatar
IMO its better to start all over fresh...the money you could put into checking for cracks etc.. just fo find out your used wore, stock stuff is okay you could of have had a new forged set...but yea TSP 347 $2800 i think...and i beleive that thunder racing does a very similar deal...good luck...
i spun a rod bearing in my 99 block...went and bought a 01 Z28 long block from a member here in SC for like $1500...still runs great.
Old Aug 21, 2007 | 10:38 AM
  #35
Patrick G's Avatar
LS1 Tech Administrator
Moved from Advanced Tech section.
Your damage is very common among nitrous and boosted motors. I've seen it for years. Time to go forged.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 21, 2007 | 10:56 AM
  #36
PREDATOR-Z's Avatar
Perhaps detonnation, severe at that.
What does the plug on that cylinder look like
Old Aug 21, 2007 | 11:31 AM
  #37
miniklr's Avatar
I assume he is running the smaller Trick Flows. Ya Blake, the heads will fit any LS engine you decide on. But like Bob said the bigger heads are going to work better on something like a 408 and up.
Old Aug 21, 2007 | 11:38 AM
  #38
DrkPhynx's Avatar
Heads and cam are considered "boosted"?
Old Aug 21, 2007 | 11:49 AM
  #39
hitmansws6's Avatar
Probably not detonation. Most likely a case of too much cylinder pressure for the stock hypereutectic piston that it fatigued and shattered. You were making a pretty good amount of horsepower.
Talked to McCord and the cheapest route would be to slap in a set of forged JEs, ARP rod bolts, bore the block +.007, re-ring and re-bearing the shortblock. You can find a used 5.7 block for around 150. You could then spin it even higher and take advantage of the heads and cam setup you already have. He also suggested bumping up the compression while you're at it to get you in the neighborhood of 11.5:1. Maybe even have the crank turned. Depends on what it looks like once you get it completely torn down.
Old Aug 21, 2007 | 11:57 AM
  #40
H82BU's Avatar
Can't do that....there is a huge hole in the right side of the cylinder wall...look at my last pic I posted and you can barley see it from the angle.
