Goodbye piston...carnage pictures inside...
Old Aug 21, 2007 | 12:05 PM
  #41
PREDATOR-Z's Avatar
Originally Posted by hitmansws6
Probably not detonation. Most likely a case of too much cylinder pressure for the stock hypereutectic piston that it fatigued and shattered. You were making a pretty good amount of horsepower.
Talked to McCord and the cheapest route would be to slap in a set of forged JEs, ARP rod bolts, bore the block +.007, re-ring and re-bearing the shortblock. You can find a used 5.7 block for around 150. You could then spin it even higher and take advantage of the heads and cam setup you already have. He also suggested bumping up the compression while you're at it to get you in the neighborhood of 11.5:1. Maybe even have the crank turned. Depends on what it looks like once you get it completely torn down.
While it might be difficult to establish unless we have more data,
I dissagree with that comment completely. i've used stock block in well over 550rwhp reliably for long times. When carnage like this happened (usualy #5 or #7) it is 80% of the time a lean condition. Those stock pistons can take a lot of abuse.
I've run 12:1 setups with juice with no failure. But lost 2 motors to lean cylinders, 1 because of stuck nitrous solinoid and another due to failed injector.
Another main cause of stock block failure is rod bolt stretch which sends the piston crashing into the valve and if at high rpm can result in the carnage you see. Being it is neither #5 or #7 on this block, that could be the cause as well.
Old Aug 21, 2007 | 03:22 PM
  #42
2 SSlow's Avatar
There is a good sized hole that you can see in the cylinder....This car needs a new shortblock and some head work at the minumum...
Old Aug 21, 2007 | 04:20 PM
  #43
TransAm578's Avatar
Originally Posted by Patrick G
Moved from Advanced Tech section.
Your damage is very common among nitrous and boosted motors. I've seen it for years. Time to go forged.
I can understand something happening like this to a boosted motor, but mine is N/A
Old Aug 21, 2007 | 04:22 PM
  #44
TransAm578's Avatar
Originally Posted by 5.3LJimmy
Looks alot like mine.
What caused this to happen to yours?
Old Aug 21, 2007 | 08:13 PM
  #45
DONAIMIAN's Avatar
I would go 383. Jason from thunder put together a mean little setup using 5.3 heads.
Old Aug 21, 2007 | 11:51 PM
  #46
TransAm578's Avatar
I think that I might try to go with an engine size that will complement the Trick Flow heads that I have already since it looks like we will be able to save them.
Old Aug 22, 2007 | 01:43 AM
  #47
Prerun4fun13's Avatar
Did you run the car without a tune for any period of time, i have heard it isnt very good to run an engine untuned for along time.
Old Aug 22, 2007 | 07:05 AM
  #48
TransAm578's Avatar
The car was never run without a tune, although it took a couple sessions to get the tune where I wanted it to be.
Old Aug 22, 2007 | 08:07 AM
  #49
Specialized's Avatar
Originally Posted by DrkPhynx
Heads and cam are considered "boosted"?
Not what he meant-
Common with the boosted/nitrous guys, the same type of thing occurs.
Old Aug 22, 2007 | 09:01 AM
  #50
5.3LJimmy's Avatar
Just tore the shortblock down about 2 weeks ago and found the bearing spun on that rod. The missing bearing material allowed the piston to crash into the head and possibly the valve. I was surprised to find this b/c the oil pressure was good and the engine was not making any audible noise prior to letting go.
Old Aug 22, 2007 | 11:32 AM
  #51
DONAIMIAN's Avatar
What I was getting at is if he made the numbers he did using 5.3 heads, im sure you could do equal to or better with the TFS heads. The two motors (346 and 383) have the same bore, so it wouldnt require the purchase of new heads either.
Old Aug 22, 2007 | 11:37 AM
  #52
mattraypharbor's Avatar
Crapy...MAN am i gonna **** my self when my engine decides to pop....prob scare the living hell out of me when it goes.
Old Aug 22, 2007 | 11:58 AM
  #53
hitmansws6's Avatar
Originally Posted by H82BU
Can't do that....there is a huge hole in the right side of the cylinder wall...look at my last pic I posted and you can barley see it from the angle.
I meant you'll need a new block too. I said it would only run you around $150 used. Bore it +.007 and slam some new pistons in that sucker.
Old Aug 22, 2007 | 12:00 PM
  #54
BQTransAm's Avatar
When my buddy did the Heads/cam swap on this car, he noticed an abundance on metal shavings on the drain plug when he drained the oil. I would say this happened due to some type of mechanical failure.
Old Aug 22, 2007 | 12:02 PM
  #55
hitmansws6's Avatar
Ring failure. Judging by the look of the valves I would say this is more likely than a lean condition. It would help to know what the plug from that cylinder looked like.
Old Aug 22, 2007 | 12:03 PM
  #56
BQTransAm's Avatar
Your wallet's life will flash before your eyes.
Old Aug 22, 2007 | 01:04 PM
  #57
Irocss85's Avatar
what inj.s are you running?
from the start, reading all the way through this, I def. agree with the point predator brought up.
might want to test them and make SURE your inj. didnt lock up and cause that cyl. to go lean. these hyper. pistons are very brittle. as in they shatter into a million pieces when they let go instead of just crack or break.
Old Aug 22, 2007 | 01:32 PM
  #58
lol THAT and the loud scary BOOM its going to make when it happens...
Old Aug 22, 2007 | 02:36 PM
  #59
gun5l1ng3r's Avatar
So can a faulty injector (one w/ 130K miles on it) cause a STOCK motor to go so lean as to destroy a piston?
Does this mean that one day, because of a partially clogged injector, I will rev it to 5K rpms and have it go lean to the point of destruction?
Old Aug 22, 2007 | 03:49 PM
  #60
H82BU's Avatar
Well at least after you are done it will be a stronger and more powerful motor. Also, this is a good learning experience.
As far as the tune, maybe we can make a trip somewhere and have it done when everything is complete......
