adjusting adjustable roller rockers on LS1?
spin the motor :
then for each cylinder :
1- when the exhaust valve starts to open adjust intake valve.
2- when the intake valve starts to close adjust exhaust valve.
is that way the same for LS1 engines?
also is that way is general for all 4-stroke engines?
thanks.
i would guess that the way i mentioned in the first post will apply for all
4-stroke engines.
i have another question : what best roller rockers for trickflow 13.5* LS1 heads? i got my heads from RayMac racing engines and they were handfinished by Chris Frank. i found in the trickflow heads sheets that they recommended using roller rockers with the trickflow heads.
i lean toward using the harland sharp non-adjustable roller rockers that is close to shaft mounted design rockers where each two rockers are tied togethor.
let me know.
thanks.
