Need quick answer,are the bolt for frt time cover same as rear
Old Aug 21, 2007 | 05:53 PM
SPRAYED 01's Avatar
Default Need quick answer,are the bolt for frt time cover same as rear
I basically have a short block and head and cam with all covers and alot of bolts. Are the bolts for the rear cover the same as the frt timing cover.
Alex
Old Aug 21, 2007 | 06:01 PM
JPH's Avatar
JPH
yes sir.
Old Aug 21, 2007 | 06:03 PM
SPRAYED 01's Avatar
Im in the process of bolting on the rear timing cover and i have what i think are the bolts. They are exactly the same as the valve cover bolts and the frt timing cover bolts. But they are to long.
Any idea
Old Aug 21, 2007 | 06:25 PM
1320 killer's Avatar
they are thesame and hold the same part number
Old Aug 21, 2007 | 06:43 PM
SPRAYED 01's Avatar
Well i must have some crazy ls1 out of an 02 z28 because they are not the same.
Wierd
Old Aug 21, 2007 | 10:51 PM
Blown86SS's Avatar
did you change the rear cover at any time??? some of the rear covers step down a little at the bolt hole, some are flat all the way across the one that steps down you cant use the same bolts as the front use the next size bolt.
Dan
Old Aug 21, 2007 | 11:30 PM
SPRAYED 01's Avatar
I recieved this engine from my speed shop. They included all the original cover the whole nine yards. This is the original block and rear cover from an 02 z28. Good new is i spoke to the speed shop and they found a bag labeled rear cover bolts. I get them tomorrow. hopefully they are the right ones. Its just really weird everyone is saying its the same part.
