2000 Rod bolts?
Old Aug 21, 2007 | 06:59 PM
djsanchez2's Avatar
Default 2000 Rod bolts?
Tried search, acting retarded for some reason.
What months did the factory rod bolts get upgraded? I only want to know if i will need to upgrade mine while doing the cam swap to spin higher rpm or not.
Old Aug 21, 2007 | 08:07 PM
snake charmer's Avatar
I eard that only a few 2000 models got te LS6 inake manifolds not sure if they got bolts but that would make sense .
Old Aug 21, 2007 | 09:39 PM
djsanchez2's Avatar
In the later part of the year they switched over to the better rod bolts. Just needed to know what month they did the switch, cuz im right in the later part of the summer.
Old Aug 23, 2007 | 05:16 AM
djsanchez2's Avatar
bump....ANYONE know this?
Old Aug 23, 2007 | 08:21 AM
litle88's Avatar
I would too!
Old Aug 23, 2007 | 10:11 AM
N4cer's Avatar
I always heard all 2000 cars got the new rod bolts.
Old Aug 23, 2007 | 10:13 AM
Mike454SS's Avatar
I'm curious too...I've seen it before, but I'd like to try to know for sure if possible.
Old Aug 23, 2007 | 10:17 AM
Mcduffys's Avatar
If you willing to take the extra time to upgrade them. Do it. It's only going to help and is a good saftey meassure.
Old Aug 23, 2007 | 11:12 PM
djsanchez2's Avatar
I don't mind doing it, i just wanted to know if it were safe to raise the limiter to 6500 when i go cammed. Or if i was on thin ice with the old bolts, i'd do it at the same time.
Old Sep 5, 2007 | 11:23 PM
djsanchez2's Avatar
Anybody? My build sheet has a date of (00/06/14) So June 14, 2000
Old Sep 7, 2007 | 12:29 AM
3fourty6's Avatar
Mines a 2000 but not sure of the build date. It's got 88,000 miles on the stock bottom end and the rev limiter is set to 7k. It spins there like a top (knock on wood) I don't think 6500 would be bad at all. If you got the time though I'd change them for safety but you hear all kinds of stories with the bolts so..............
