Changing cam
Old Aug 25, 2007 | 02:45 PM
85ta383's Avatar
i have mti stage 2e's but you vould go wiyth some miled 5.3's and be good to go.. do a search and find a setup you like.
Old Aug 25, 2007 | 03:13 PM
Dragkid1917's Avatar
you could just advance the cam when installing to lower the powerband.... the 233/239 power band actually peakes 300 rpm lower then the ms3. I think with the converter itll run awsome, A dyno queen cam is more like an MS4, whick if u look at the specs, is a big diff.
Old Aug 25, 2007 | 03:49 PM
therobman's Avatar
idk i want the magic 400 i know its all about the curve but i want 400 rwhp lookin at either the tsp233/239 or 228R
Old Aug 25, 2007 | 03:58 PM
john563's Avatar
Originally Posted by 85ta383
had a 230 236 custom cam.. and swapped it out for the 224r.. i have no regrets.. just put that sucker in! then if its not enough get some heads/intake.
I have a tr224/112 cam and was recommended a 230/236 111lsa+2. What was the 230/236 like for you,as far as driveability,power range,and how much more rwhp did you gain over the 224. please pm me and let me know
Old Aug 25, 2007 | 04:02 PM
as for the 233/239, ill have the dyno graphs soon enough, however i called TSP and talked to them and its not a dyno queen cam, it does infact preform, especially with a stall. If you want you can lower the band by advancing it, and when u do heads it will pick up even more h/p cuz the cam is letting it flow alot. as i said its not like an MS4 where the power really comes in at like 6500, it makes power much lower then that too
Old Aug 25, 2007 | 06:51 PM
gts500's Avatar
you can easly hit 400 with 224 just get a goot set of heads and thats it.you should look at heads like AFR 205-patriot stage 1 ls6-DART 205-levirnois-TSP.make a search man.(its all about how much you can afford)
Old Aug 25, 2007 | 07:49 PM
01redws6ta's Avatar
My combo put down 403 RWHP at 6200 RPM this week on a Mustang dyno while being tuned. Mine is a 6 speed though. (See sig.).
Old Aug 25, 2007 | 10:31 PM
CODE4LS1's Avatar
I have a 224/224 .581/.581 112 on my A4 Vette, Excellent torque throughout the powerband. Good cam.
 Michael S. Palmer
Old Aug 29, 2007 | 04:59 PM
Tram's Avatar
robman- Did you decide on the cam yet?
I am sitting here doing the same thing..
I want either a heads/cam swap or just a cam.. I can't make up my mind.. I'd really like to hit 400+ so I'm pretty sure I'm going to go with a set of Patriot heads..
