Head Gaskets and bolts
Old Sep 2, 2007 | 04:24 PM
blueeyeddevil141's Avatar
Default Head Gaskets and bolts
I have 120k on my motor, and I just put a Vindicator(240/244 .608/.596 113LSA 111ICL) in and I need head gaskets, intake gaskets, and head bolts. Which gaskets and bolts are suggested? Do I need anything else?
Old Sep 2, 2007 | 05:51 PM
bigdsz's Avatar
If you didn't notch your pistons, no use putting it back together. PTV is a distinct reality.
Old Sep 2, 2007 | 07:04 PM
HEMIETR's Avatar
+1 I would check PTV clearance. IF you have clearance. Then measure the deck height and determine from there what head gasket to use.
Old Sep 2, 2007 | 08:03 PM
snake charmer's Avatar
stock is .052 so if you go with .040 cometic which is popular as it will bump compression up and thus add and compliment the cam you went with .
though since it is so big it is always a good idea to check piston to valve clearence though .012 is not too big of a difference .
that being said better safe than sorry .
arp makes good head bolts and in a high performance application are good to go with . these bolts are really strong and can be used again unlike stock gm bolts .
intake gaskets are really about the same . if your old ones are melted it will help with any leaks .
Old Sep 2, 2007 | 09:19 PM
LS1Z28-00's Avatar
i got mine from texas speed. the head gasket and bolts were 100$, its a great deal being the dealership wanted 250$.
Old Sep 4, 2007 | 01:53 PM
JasonWW's Avatar
$250!?
The graphite gaskets for my car were $40 list each and the headbolt kit is $24 list for each side.
From GM Parts Direct pricing:
12558809 $23.58 right
12558810 $23.58 left
12498545 $17.47
So $82.10 plus shipping
Old Sep 9, 2007 | 05:00 PM
Tram's Avatar
You got ARP head bolts for $100?
Old Sep 9, 2007 | 06:18 PM
98Camarod's Avatar
I did too.
Old Sep 9, 2007 | 06:21 PM
Tram's Avatar
I guess the prices went up... $150 now..
Unless I am looking at the wrong ones?
http://www.texas-speed.com/shop/item...id=92&catid=36
http://www.texas-speed.com/shop/item...d=798&catid=36
