slight tapping in engine
Old Sep 2, 2007 | 07:56 PM
boola1341's Avatar
Default slight tapping in engine
My car is a 02 z28 a4 camaro with 80k. when i start my car its running normal until it gets around 160 degrees. A tapping noise starts to sound in the engine. when i rev the car to 2k or 3k rpm's a few times the noise stops but comes back after 30 seconds or so. could it just need a engine flush. the type of oil i'm using is mobile 1 5w30. what do you guys think. what type of oil additive do you guys use
Old Sep 4, 2007 | 11:50 AM
heavy6.0's Avatar
sounds like a lifter going south. when you are reving the engine it increases oil pressure thereby helping to pump up the lifter. you may also have a bent pushrod which pretty common.
Old Sep 4, 2007 | 06:05 PM
boola1341's Avatar
i wonder if that's covered under the warranty. the warranty doesn't expire till april '08. i'll get mr. goodwrench to check it out
Old Sep 4, 2007 | 07:30 PM
delsold's Avatar
ya maybe drain all the oil out, run it for a good hour or so until you realllllly start to hear that tapping. then take it to mr. goodwrench and get a brand new ls1
Old Sep 5, 2007 | 05:15 PM
boola1341's Avatar
hahaha
