please help with problem
Old Sep 3, 2007 | 07:17 PM
turbo408stroker's Avatar
Default please help with problem
i installed a hp turbo kit its a gt45r 75 lbs injectors with magnafuel pump on my 408 stroker now that i got it done i have codes being thrown here they are
U1301 - Class 2 Short to Battery
U1016 - Loss of Class 2 Communication with VCM
U1040 - Loss of Class 2 Communications with ABS
U1096 - Loss of Communications with IPC
and a camshaft position sensor circuit high and low
when i delete the codes all come back immediately. except for the throttle position sensor. when i start the car it runns good for hte first ten seconds then my tach drops down and the cam shaft position sensor circuit high and circuit low come back. i have checked all fuses and wires and all grounds. please help thanxs
Old Sep 3, 2007 | 09:49 PM
Default anybody
anybody
