Driveability: Patriot Heads 59cc vs 64cc
Old 09-07-2007 | 03:58 AM
aero_ub's Avatar
Computing it isn't a problem...knowing what is an acceptable level for the LS1's is my problem lol
Old 09-07-2007 | 06:51 AM
GuitsBoy's Avatar
Stock LS1
Bore: 3.898
Stroke: 3.662
Rod Length: 6.098
Number of Cylinders: 8
Deck Height: -.007 (O.O.H.)
Piston Dome or Dish in cc: 0
Compressed head gasket thickness: .053
Cylinder head chamber volume: 66.67
Old 09-07-2007 | 08:04 AM
brad8266's Avatar
Originally Posted by aero_ub
A lot of people seem to be missing the fact or not understanding that your static compression ratio due to running 59cc heads doesn't mean much at all when determining if you can run them on 91 or 93 octane. You could have an engine with a 12:1 static CR that runs fine on 91 and another with a 10.5:1 static CR that needs race gas to not get detonation (you get the idea). What matters is your Dynamic CR. That is determined by when your intake valve closes on the compression stroke (degrees ABDC) and that is determined by your cam. The cam is what’s important here.
So, how many people here running the 59cc heads actually calculated or know what their dynamic compression ratio is with their specific cam? Where is your DCR and what octane are you running?
My issue right now with making my H/C selection and calcs is that I do not really know at what DCR does running on 93 octane because an issue? What is a reasonably safe DCR to run on an LS1? I know that once you get in the area 8.5:1 and up you better start paying attention. But, there are many aspects of an engine/head design that effect and determine when you are going to get into a dangerous area.
aero
You aer 100% correct on that, DCR is what really matters. Mines around 8.7-8.8 DCR. I would imagine that a stock cam in an LS1 matched with some 59cc heads is going to make a lot of DCR. Im too lazy to run the numbers right now though.
Old 09-07-2007 | 04:30 PM
hammertime's Avatar
The 212/218 .558/.563 115* LSA cam yields a rather high 8.08 DCR with stock LS1 chambers and stock MLS .053 thick gaskets. Just dropping down to a .040 thick gasket bumps that to an 8.31 DCR. Further reducing the chambers to a 64cc LS6 style head give an 8.59 DCR.
For a daily driver, with variable qualities of fuel, I'd leave well enough alone at that. Keep in mind, this is installed at a 115* ICL; advanced two degrees brings that up to 8.73 DCR. Many Comp cams are ground advanced 4 degrees, which would likely put you over the limits of 93 octane at 8.86 DCR.
aero_ub - general rule of thumb is to get your DCR up to 8.5 for best power and throttle response through the mid-range. 8.5 to 8.7 is a safe acceptable range for 93 octane fuel without major attention to detail in engine assembly and tuning. To squeeze more than 8.7 out of 93, you need the tightest quench you can safely run (.034 - .030) without risking a piston rocking into the deck surface of the head. An excellent drivability tune with emphasis on spark timing and AFR in high load, low rpm areas is critical.
Keep in mind, this is specific to the LS1. I wouldn't advise anyone try that with a larger bore or lazy combustion chamber, such as 400 gen1 SBC or any BBC.
Old 09-07-2007 | 06:46 PM
Z06FRC's Avatar
I talked to Gunnar from Patriot Performance. He said that I can run 91 octane fuel with no problems at all with this head and cam setup. Even with the .040 gasket heads. Plus I'm getting the heads with an Intake Valve Diameter of 2.02".
Old 09-08-2007 | 03:29 AM
allthrotle's Avatar
Im running a 228/230 cam with .585 lift with the 59cc heads and I daily drive my car on 91 octane, NO PROBLEMS.
Quick Reply: Driveability: Patriot Heads 59cc vs 64cc
