pulley is stuck how do i get that thing out
Old Sep 5, 2007 | 09:37 PM
santiago's Avatar
Default pulley is stuck how do i get that thing out
well once again i did something stupid i found out i needed to machine the pulley after i put it on.
im using the tool were you screw 3 bolts into the pulley to get it out and it not budging i tried heating it with a torch and now i fried my front cover seal .
search on here sucks
what do i do now??
Old Sep 5, 2007 | 09:41 PM
SoCal01z28's Avatar
spray rust penetrant and keep cranking, everytime i take mine off i get pist and think it's frozen on but it always ends up coming off
Old Sep 5, 2007 | 10:12 PM
The PAT WS6's Avatar
used the pos tool with the 3 jaw puller from orielys works great.to put it back on use longer bolt
Old Sep 5, 2007 | 10:22 PM
88zukon36s's Avatar
it is a after market pully he is using the rite puller. just keep turning it it will come. Are you using the bolt to push from with the puller. make sure the bolt is not tight so the pully will come off. good lick.
Old Sep 5, 2007 | 11:22 PM
santiago's Avatar
im using this tool kit. i keep turning but it is not budging im afraid those 3 bolts are gonna pull the threads right out.
yes the 3 jaw puller will not work it will leave lil indents...good thing im not running a/c.
anybody got anymore tricks???
powerbond pulley+double roller timing chain=
Old Sep 5, 2007 | 11:40 PM
ArrestMeRed99Z28's Avatar
pull REALLY hard . All kidding aside I've never seen one come off easily, get angry and go at it.
AJ
Old Sep 5, 2007 | 11:46 PM
217zenki's Avatar
pb blaster that bitch into next week.
Old Sep 6, 2007 | 05:29 AM
vettenuts's Avatar
That's a total recipe for disaster, he has a Powerbond and a longer bolt will screw up the crank threads.
Old Sep 6, 2007 | 10:47 AM
RZRSEDGE's Avatar
Crank it hard. It sucks, but it will come.
Old Sep 6, 2007 | 01:47 PM
sixthfloorfreak's Avatar
i wholeheartedly believe that PB Blaster helped mine come off
Old Sep 6, 2007 | 04:13 PM
GuitsBoy's Avatar
I love the PB blaster. I hate the crank pulley.
Old Sep 6, 2007 | 09:24 PM
santiago's Avatar
wuts pb blaster?
Old Sep 6, 2007 | 09:31 PM
kistlerjm9's Avatar
its a penetrating oil called punk buster
Old Sep 6, 2007 | 10:36 PM
santiago's Avatar
where do i get that?
Old Sep 6, 2007 | 10:46 PM
kistlerjm9's Avatar
looks like this and any parts store should have it
Old Sep 6, 2007 | 10:56 PM
santiago's Avatar
oh **** my dad uses that ****. so do i jus spray it all over or wut?
Old Sep 6, 2007 | 11:04 PM
Hennytime's Avatar
that **** kicks ***, but spray it on heavy, leave it over night and then spray a few minutes before hand and itll come right off
Old Sep 7, 2007 | 09:28 PM
santiago's Avatar
guys....thanks for the replys ill report back with my findings.
Old Sep 23, 2007 | 06:52 PM
santiago's Avatar
jesus christ! i torched it and used a 1/2 impact wrench and that bitch is still not comin out wut gives? my seal for my timing cover is cmpletely fried now my only option is to get a stronger impact.
Old Sep 23, 2007 | 08:05 PM
vettenuts's Avatar
Sounds like it galled when it went on the first time, did you use any anti-seize?
