Feel Like I wasted $$ on Cam Install!!
Even with the rod it still managed to drop a bit. So to fix the problem i re-installed the MS3 and when i got to that point a friend of mine used a pen magnet to bring the lifter back up, problem solved. I think even if i would have spent the money on the jrp lifter tool it still would have happened. The dowel rods do work great, but you must remember that they ain't perfect.
-Joel
She gives me a hard time about my dad.. She thinks he's hot, or whatever.. So I'm like yeh, well.. your sisters younger and bangin..
Damn, sounds like a future episode of Jerry Springer
the flat side of the rod lets you slide it in, then you turn it until it snugs up with a round edge pushing against the lifters. I made my wn with 5/16 metal dowel ****, ground down one whole edge of it. Slid right in, and when turned tight it held them so well that you couldn't turn the dowel all the way around, it snugged them up very nicely
Couldn't be easier.
Re'
2 5/16" rods(round stock/dowels or whatever you call them), make them approx. 25" long,
bullet one end like they said and mark exactly 19" on the rod
when the mark is flush with front of the block you know that you are all the way in
I bent the extra 6" to make a handle but be sure that the other 19" is straight
also I didn't have to flatten one egde, tight fit on passenger side but went in
made swap very easy
oh and everything only cost around $6.75
, seriously though...
