Cam Swap in Progress, Need Help Fast....
Old Sep 14, 2007 | 08:43 PM
PBMFIsMe's Avatar
When you put the timing chain sprocket back on, it will pull forward to where it needs to be.
There is a little extra room there...not to worry.
Old Sep 14, 2007 | 09:06 PM
madclown's Avatar
Thats what I thought.... It just seems to mve further back than the stock one did.... Anyone else??????
Old Sep 14, 2007 | 09:57 PM
madclown's Avatar
Any other thoughts????
Old Sep 15, 2007 | 12:04 PM
madclown's Avatar
Well I guess when I bolt up the cam sprocket it will pull the cam into place. So what stpos the cam and sprocket from "floating a little bit" in the block?
Old Sep 15, 2007 | 03:36 PM
eallanboggs's Avatar
It "floats". The cam plate keeps it from coming too far forward. The chain determines where the cam sprocket rides which in turn controls where the cam resides. A Torrington bearing as found on timing sets like Rollmaster acts as a buffer if the cam sprocket "floats" too far rearward.
Old Sep 16, 2007 | 01:00 AM
madclown's Avatar
Thanks for the input....
Old Sep 16, 2007 | 03:35 AM
99DWPTA's Avatar
we used 150psi on mine
