Installing engine....with or without headers?
Old Jun 2, 2003 | 09:54 AM
Phil99vette's Avatar
7 Second Club
Default Installing engine....with or without headers?
I am getting ready to install my motor in my 99 corvette and wondering if I should go ahead and bolt the headers, coil packs and the other little stuff? Should I bolt them up outside or inside the car?
Phillip
Old Jun 2, 2003 | 10:33 AM
malibu350's Avatar
Default Re: Installing engine....with or without headers?
Well if I was installing a motor in my 99 TA and was going in from the top I would not install everything, but if you are going at it from the bottom...I would attach everything except the hoses and the wiring harness......good luck
Old Jun 2, 2003 | 09:01 PM
2001 Pewter WS6's Avatar
Restricted User
Install the block and bolt the heads on later. That is how I took amine out and how I am going to put it back in. My tranny is still in place and it is easy to bolt it to the tranny this way.
Old Jun 2, 2003 | 09:08 PM
Crazyquik's Avatar
and headers go on *easy* when the heads aren't bolted down, just slide in the headers, set the heads on, then bolt down the heads and put on the headers
J.
