Need help after cam install
Hey guys I trying to help a friend out that had a cam install go bad. What happened is he installed a LS6 cam 180* out. Figured out pretty quickly that it wouldn't start and reintalled with the correct timing, only now the car still won't start. I don't believe there is any engine damage it just looks like the car isn't firing at the correct time. I thought maybe he damaged his camshaft position sensor, is this possible on a cam install. Any ideas on how to help him get this fixed?
i wouldnt think it would be that...and ultimately I am not sure of any reasons it wouldn't fire outside the typical checking coil packs etc etc so sorry i cant help you out, but i will bump this one up hopefully someone can help u out!
