Need cam recommendation, No tuning, no LS6 cam.
What the title says, Looking for a good cam that will give me 25 to 30 hp with good torque all around and hp. Dont want all top end. Check sig for my mods, also must work with my small converter and 273gears. Thanks
Re: Need cam recommendation, No tuning, no LS6 cam.
I picked up 31rwhp on a B1 cam, no tuning except MAF translator, on an M6, through shortie headers. You might want to raise the limiter though if you are going to run NA a lot, because although it peaks at 6100, it rides out pretty flat to 6500.
The split duration cams suggested (like the 212/218, or even a bit bigger) work well for nitrous because of the extended exhaust duration.
