Is it possible to install a camshaft "upside-down"
Old Jun 9, 2018 | 08:47 AM
truckdoug's Avatar
Originally Posted by eallanboggs
When you ask a question and some people say yes and others say no you should be able to figure out that you don't know the REAL question you want to ask OR how to ask it Some people figured this out as I did and gave you mocking answers as I often do You need to study 4 stroke theory some more so you know how it works then ask your question Before the chain is installed there are NO STROKES The cam and crank don't even know each other exist The crank is the heart and the cam is the brains When you MARRY the cam to the crank with the chain they have 4 babies the very day they get married Their names are Intake, Compression, Combustion and Exhaust They are born in a specific order and they must maintain this order and relationship to the crank for the engine to work correctly I believe I know what question you want to ask, but you need to study more so you can ask the correct question which leads to the answer you want
if they have 4 babies the day they get married,
The hell was that motor doing 9 months ago?
Old Jun 9, 2018 | 09:40 AM
LOL!! You just made my morning!
Old Jun 24, 2018 | 08:09 PM
nixc5's Avatar
So I took the valve covers off and put in a in-line spark tester on cylinder 1. With a friend turning over the engine I noted the cylinder was firing while the Intake valve was still open. I checked a couple other cylinders and noted the same. I changed out the brand new crankshaft sensor with another new one and bam she fired right up. Cannot get her to idle yet but that is just the next problem.
Old Jun 29, 2018 | 01:47 PM
SRT8.Acelleration's Avatar
ITS EASY..
Old Jun 29, 2018 | 10:12 PM
RockinWs6's Avatar
Is it possible to install a camshaft "upside-down" Only in Australia!
Old Jun 30, 2018 | 01:11 AM
LLLosingit's Avatar
Reading that made my head hurt and I haven't even been drinking. That's one loooooooooooooooooooooooong sentence lol
Old Jun 30, 2018 | 01:30 AM
Fuhnortoner's Avatar
This thread is cancer.
Old Jun 30, 2018 | 11:23 AM
The capital letters are there He just didn't use punctuation I didn't either You just have to learn to read it LOL
Old Jun 30, 2018 | 11:20 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
He made one hell of a good point, though. I would hate to count the times I have had to explain to someone that in order to get the answers they want, they need to learn enough to ask the right questions. You end up in a downward spiral until you find their baseline knowledge, then you start from there.
Old Jul 1, 2018 | 09:10 AM
RB04Av's Avatar
Punctuation and capitalization are the difference between "I helped my uncle, Jack, off his horse" and ... something else.
Old Jul 1, 2018 | 12:17 PM
LLLosingit's Avatar
Perfect lol
Old Jul 1, 2018 | 01:52 PM
  #32
pantera_efi's Avatar
Default OHC engine with "upsidedown" cam timing
Hi ALL, THIS THREAD is GREAT AND NO ONE HERE has PROVIDED EVEN ONE REASON to do so, to install a camshaft "upside down".
I work with OHC cam engines OFTEN !
MOST applications are for Off Road racing, LOW END Torque increases, WHEN I install a camshaft Up-Side-Down.
The MOST common application is a class 7S truck using one of the Ford's V-6 engines.
The second is a Class 1 Buggy with Porsche 911 based engines.
The result is that TWO cylinder FIRE at the same time, a three cylinder engine sound is heard.
This style of engine operation makes for good driving up a sand wash OR on a Goat trail.
THUS to ALL HERE who made fun of this REQUEST, better get a new job !
Those who want to fit an upside down Crower Cams Copper camshaft can order one from Pantera EFI.
The engine will sound like a 308 GTS OR a Ford Mustang, the one with 180* crankshaft. (these engine have upside down camshafts)
Lance
Old Jul 2, 2018 | 02:38 AM
  #33
LLLosingit's Avatar
Lance you might want to reread the first post, I think you missed the meaning of his post.
Originally Posted by JoeMamma AngieDaddy
I'm definatly overcomplicating a simple issue. Here is the thing. I think I pulled the stock cam out with crank-gear dot "up" and camshaft dot "up" as well. Then I reinstalled the camshaft "dot-to-dot" (crank dot up and cam dot down) then I decided it would be a good idea to make sure I didn't curse my self so I'm doing some follow up. How does the engine know when to pulse the injectors and the spark?
Lance
Old Jul 3, 2018 | 09:46 AM
  #34
Default LS Four/Twin Fire Camshaft
Hi LLL, YES I read the post, the OP question is VALID.
The OP has an invention, the UP SIDE DOWN camshaft.
REMEMBER the Clay Smith 1/4 Speed camshaft ?
THUS if I place 1/2 of the cam lobes Up Side Down, I will have TWO cylinders firing at the same time.
The result is a different torque pulse into the drive train, GOOD for some types of racing ?
This firing method IS common in F-1 engines.
Lance
Old Jul 3, 2018 | 04:22 PM
  #35
LLLosingit's Avatar
Lance, He was asking if he screwed up while installing the stock cam so I don't have any idea how you came to that conclusion.
