Oil & spark plug holes
I guess when I do my cam/heads swap in couple weeks, I can really get a good look at things.
Turns out it was nothing more than a previous owner doing their job by pasting the plug threads with antisieze.
The antisieze must get warm and some of the residual must seep down the side of the block. Here are some pics....
http://www.villagephotos.com/pubbrow...der_id=1916492
Oil cannot come from bad rings in an amount enough to soak a spark plug thread. Oil can't travel upward after the engine is turned off to get ot the plug holes, and while the engine is running the oil is being burned and blown out the exhaust. If it was the rings you would be burning so much oil that you'd be leaving a trail of white/blue smoke that could be seen from space and you would be running so rich from the PCM trying to compensate that you would get 5 mpg.
Do you mean the oil is dripping down the outside of the heads and onto the spark plugs from the outside of the engine?
