Comp #26928 Springs
Old Sep 25, 2007 | 09:26 PM
Last C5's Avatar
Default Comp #26928 Springs
Does anyone have a source for Comp Cam's new 928 springs? They look like a good upgrade from the 918s, but I can't find a lot of information on them and my e-mail to Comp has gone unanswered. Maybe I should be looking at Patriots or Cranes.
Old Sep 25, 2007 | 10:16 PM
DONAIMIAN's Avatar
If you can get away with a single behive valvespring do so. Its a better choice if you dont need duals.
Old Sep 25, 2007 | 10:36 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Depends on his setup too. Maybe he is pulling a you and going solid?
Old Sep 25, 2007 | 11:29 PM
DONAIMIAN's Avatar
After what im gona do im sure it will convince more people to go my route, lol.
Old Sep 26, 2007 | 01:01 AM
Last C5's Avatar
Default 928 info ??
Given I have the stock lifters and cam I figured that the single springs were the way to go. These new 928s are beehives with a .650 lift capability and a 125 lb seat pressure at a 1.8 installed height, but that's all I can find out about them. I'd like to know the spring rate, coil bind height, and open load at 1.200. Supposedly they will be an upgraded replacement for the 918s and the 918s will be phased out.
