ARP thread sealer or lube for Studs
Old Sep 26, 2007 | 11:30 AM
xBROKEx's Avatar
Default ARP thread sealer or lube for Studs
im going to be using ARP headstuds on my prc 2.5 5.3L head install, should i be using the thread sealer or the arp assembly lube for these?
Old Sep 26, 2007 | 11:44 AM
JPH's Avatar
JPH
arp assembly lube, and go by assembly lube trq. specs also.
Old Sep 26, 2007 | 11:51 AM
xBROKEx's Avatar
but you dont torque the studs into the block, i know for bolts you should use the lube, but since you dont torque studs down into the bolt wouldnt sealer be better to keep the coolant from leaking into the threads??
Old Sep 26, 2007 | 11:59 AM
JPH's Avatar
JPH
run studs into block hand tight, w/assembly lube or sealant (bolt holes are blind), and then after the head gasket and head is on, install washer and nut using assembly lube on both sides of washer and trq. to arp spec using there assembly lube. 70ft. lbs large studs, 25ft. lbs small studs(8mm).
xBROKEx's Avatar
oh ok, that makes sense
