TSP Torquer-2 (232/234) on a full bolt-on car?
I am liking what I have been reading about the TSP Torquer-2 232/234 .595/.598 Camshaft, I have been leaning towards a 113 LSA, because I am worried the 112 LSA will just be too aggressive..
My mods are in my signature below...
Besides a new rear end and with some gears in the future (15-16 months)and of course re-tuning the car, this will be the last modification on my car.
That means stock clutch, stock fuel system, and stock intake setup (LS6), ect...
Am I thinking too big with my daily driven car with my current setup?
How good will this cam be for a daily driver cam only setup?
I would also like to see near 400rwhp.
Thanks in advance,
-John K.
and i agree with above...stock clutch won't handle that power. my clutch was slipping when i had mine dynoed...and that was only at 380rwhp
113LSA
Would you suggest a 111LSA on the TV2 or are you saying just get the TV3 instead? Also if your saying get it on the TV2 would you still get +2?
i'd go with the 112 or the 112+2 as suggested, you'll be happy you did since it will get you a little more torque down low
so for more power in the low rpm range you are better off with something in the 110-112 range....
that is why alot of people complain about how high the power comes in for the LS6 cam....because it has something like a 117.5 LSA
increasing the LSA will smooth out the idle and also reduce emissions (i think) due to less overlap. that is why factory cams are designed that way. so with a lower LSA you'll have better low end power, but at the cost of a choppy idle.
my 112 idles nice...even with poly motor mounts it really doesn't vibrate much.
227/230 .639/.609 114+4 LSA
No Harley lope, more trq than you can handle and nice peak power that will outdo the TV2.
LSK/XFI lobes
You can grind it at TSP or Thunder (my choice)
LSK/XFI lobes
Do what this guy says!
btw i dynoed 391rwhp 362rwtq through stock exhaust and 407rwhp 372rwtq with open cutout. keep in mind this is through tsp catted y-pipe stock tb, and ls6 intake. theres some extra hp if i deleted my cats and port out my tb
