LS2 short block w/ LS6 heads?
Old Sep 28, 2007 | 02:04 PM
robertbartsch's Avatar
Default LS2 short block w/ LS6 heads?
Will an LS2 short block work with LS6 heads, intake, oil pan, timing cover, cam sensor, A/C. P/S. accessories etc.?
Will EVERYTHING bolt up?
Old Sep 28, 2007 | 03:59 PM
gmguy4life's Avatar
I'm not sure what you are saying but the stock factory LS2 has 243 heads that was used on the LS6.
Old Sep 28, 2007 | 05:58 PM
silver01z06's Avatar
ls2's had ls6 heads from the factory...
Old Sep 28, 2007 | 06:04 PM
PSJ's Avatar
PSJ
Yes and No.
Yes they have the 243 LS6 head " casting " but not the LS6 " light-weight " valves.
PSJ aka Marc
Old Sep 29, 2007 | 08:04 AM
N4cer's Avatar
And no, the LS6 is the Gen III. LS2 is Gen IV. So your valley cover, front & rear covers won't match.
Old Sep 29, 2007 | 08:33 AM
98SS1LWEE's Avatar
No, front and rear, and valley cover might not, but everything you asked about will work. So the answer to you question is.....................................
YES
Old Sep 30, 2007 | 10:24 AM
RGKSR's Avatar
Default LS1 to LS2 = Easy
I swapped a LS2 into my C5. Relocate the knock sessors, a few harnesses and covers and your done. No big deal.
Bob K.
