small problem
Old Oct 2, 2007 | 08:50 PM
diablo078's Avatar
Default small problem
i have an 2000 camaro a4. A problem im having is that once in awhile after driving I can hear air bubbles in the radiator, but the gauge doesn’t read hot as if its overheating. its not low on coolant and there is no leak around the radiator or the water pump. i added dye then pressurized the system, no leaks anywhere, no coolant in the oil. Another problem im having is that the ASR will turn off and trans slips like crazy and shifts hard as hell.
Old Oct 2, 2007 | 10:32 PM
88zukon36s's Avatar
do you just hear a bubling sound or are you looking at bubbles in the rediator?
Old Oct 3, 2007 | 01:32 AM
diablo078's Avatar
i just hear bubbles
Old Oct 3, 2007 | 05:49 AM
Thule's Avatar
open the radiator and se if it bubles there, is the coolant level getting lower?
Old Oct 3, 2007 | 12:12 PM
diablo078's Avatar
what does it mean if the coolant keeps getting low? blown head gasket?
Old Oct 7, 2007 | 11:51 AM
diablo078's Avatar
sometimes the coolant gets low.
