Xe-r Lobe * 1.8 Rocker = Lsk Lobe ??
Old 10-08-2007, 09:04 AM
dmiz0420's Avatar
Default Xe-r Lobe * 1.8 Rocker = Lsk Lobe ??
QUESTION:
Basically would using a xer lobe with 1.8 rockers give me close to an lsk lobe for ramp rate(More, Less)? Would 1.8 ratio with an x-rpm give me close to the ramp rate of an xer(More, Less)?
IE:
A 224 .581 comp xer lobe (with a 1.8 rocker is .615) lift for the intake and a xtreme rpm 224 .568 lift on the exhust (1.8 ratio is .605) on a 111lsa (open to suggestion on a 110 or 112 +?)
Old 10-08-2007, 10:01 AM
PREDATOR-Z's Avatar
That is not a good idea. The ramp rate of the XE-R will be too much to handle by the rockers and you'll experience difficulties, like floating.
If you want more lift just swap cam.
Old 10-08-2007, 10:48 AM
dmiz0420's Avatar
darn, Thanks, just trying to avoid swapping the 1.8's I already have for 1.7 but still take adventage of the great low end tq and under curve power of the lsk / xer lobe combo for road racing/hpde on small, hight flow & velocity runners (202cc)w/ stock cubes
Pred z, Thanks for your answers on other's posts as well, I really appreciate and get a lot out of them.
Old 10-08-2007, 11:13 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
You could probably design a cam that takes advantage of your 1.8 rockers. People do it all the time.
Old 10-08-2007, 03:25 PM
RE AND CHERYL's Avatar
What PREDATOR said. With the aggressive ramps on newer cams almost all of them say not to use rocker arm ratios higher than stock for a street driven car. It will destroy valve spring life.
On the bright side you could always have a custom cam ground to use with your current 1.8RRs
Re'
Old 10-09-2007, 12:23 AM
N4cer's Avatar
Or it shouldn't be too hard to find someone who will trade their stock rockers for your 1.8's.
Old 10-09-2007, 10:01 AM
dmiz0420's Avatar
Someone would want to trade their stock bearing spillers for my yella terra 1.8 shaft mount roller?
Thanks guys,
I'm going to look into a custom grind or just selling the 1.8 yt and buying the 1.7's and use the cam to limit the hp to the stock bottom end what say 475 rwhp & tq or something like that.
