What else is needed from parts store for a cam install?
Timing cover gasket
Timing cover seal
Water pump gaskets
New Crank bolt
Thats just your basic GM cam install kit. Tool wise you'll want a good pulley puller for the balancer & something to hold the lifters up if your not doin heads also. No special lube needed, just put some oil on the cam lobes & you'll be alright. You should probably be doin a set of springs along with the cam so you'll need a spring compressor tool also.
i needed about 30 beers or so for the cam/heads/headers/intake of mine...lol
If you're not pulling the heads, you will need something to hold the lifters up. You can spend $90 on a special tool or $2 on some 5/16" wood dowel rods, either will work. If you're changing the springs you will need a spring compressor. You can either use the TDC method to keep the valves from falling or use an air compressor and the hose from a compression tester to keep them up.
It might help to have a friend to help you get the radiator out, it is a bear by yourself. There are tabs that hold the radiator onto the AC condensor which make it a pain to get out by yourself.
edit:
looks like we have a very similar setup... why did you go with new rockers and injectors? just curious... Also have you dynoed it yet? what kind of numbers are you pulling? I have a 12 bolt so I probably will make a bit less, though the aluminum flywheel should help
MS3, MS4, Texas giant....
I wonder if this is limiting my CR and the Tv2 looks like it should make better low end torque... now Im having 2nd thoughts..
http://www.ls1howto.com/index.php?article=23
