2002 GM MLS Gasket
GM does not show that the 2002 gasket can be used on the 2001. The main difference that I can see is the thickness. The 2001 is 1.002 mm and the 2002 is 1.33 mm. Go aftermarket, Cometic and Felpro make a bunch of different thicknesses.
Yes you can. Both the 01 and 02 cars should use a MLS gasket that claims to be .060, but usually mic's out to around .053. You cant run these gaskets on older 98 heads because they have a notch that would allow water to leak right out.
