oil pressure
Old Oct 11, 2007 | 06:28 PM
texasheat's Avatar
Default oil pressure
My oil pressure is at 35psi during idle and my valvetrain sure is getting noisey..could my oil pump be going out. Car has 89,000 miles. Still has stock ls6 pump.
Old Oct 11, 2007 | 06:34 PM
bad6as's Avatar
what kind of oil and filter?
oil will get thiner when its hot, but 35psi sounds fine
Old Oct 11, 2007 | 07:11 PM
texasheat's Avatar
castrol 0w30 k&n extended oil filter...model 2006
Old Oct 11, 2007 | 07:38 PM
bad6as's Avatar
what kind of temps do you have where you live?
how long have you had the parts installed?
Old Oct 11, 2007 | 09:26 PM
texasheat's Avatar
HOT! I live in texas and its around 90-95 everyday. Had them in for about 1000 miles.
Old Oct 12, 2007 | 09:31 AM
GuitsBoy's Avatar
what kind of oil pressure did you used to have? Do you have any oil pressure fluctuation? Also, the cam and valvetrain parts are 1000 miles old?
Old Oct 12, 2007 | 11:16 AM
john563's Avatar
I'm here in Ohio and we had a real hot summer in the high 90's. My pressure was in the 35 ranges once driving for about 20 minutes or so.We had a sudden srop in temp here and its right around 40ps1 once fully warm,but were are in the 50's right now here.Could be that i did not drive it long enough as I did the last time,but 35psi sounds fine to me
