copper spray issues
Old Oct 11, 2007 | 10:26 PM
xBROKEx's Avatar
Default copper spray issues
I used some copper spray on my cometics and some of it came off when i was slidding the gasket on, i was told it should be a problem. AM i in for a leaky head gasket?
Old Oct 11, 2007 | 10:32 PM
pewter 01 SS's Avatar
well if some came of it just re-spray the gasket. when i used cometics in the past i use to spray them also, but onces i finished applying at least 3 coats to each side i let them dry really good before i installed them but when i installed them i tryied being as carefull as i could be. I recommend respray them before you put the heads on just in case they do leak.
Old Oct 11, 2007 | 10:40 PM
blueeyeddevil141's Avatar
Wait, I gotta get that copper spray **** for my head gaskets?
Old Oct 11, 2007 | 10:48 PM
xBROKEx's Avatar
to late i already bolted it all back together, if it starts to leak ill just go get some gm MLS gaskets i guess
Old Oct 11, 2007 | 11:00 PM
xBROKEx's Avatar
im still wondering if this would even cause a sealing issue
Old Oct 11, 2007 | 11:27 PM
jegten's Avatar
if it starts to leak, just clean them up again, and apply the copper spray as recommended in the prior post. you can reuse your cometics.
Old Oct 11, 2007 | 11:31 PM
xBROKEx's Avatar
its hard to get them on the studs without wiggling them hengce the parts missing some, if it leaks ill just clean them and put them on dry
Old Oct 12, 2007 | 09:47 AM
CodeName Z06's Avatar
Doesn't cometic recommend a dry install, or it the copper spray jsut for added secuity?
Old Oct 12, 2007 | 01:27 PM
1997bird's Avatar
If it starts to leak use silver spray paint instead of the copper spray. Let it dry and re-install the gaskets. The silver spray paint has worked better for me than the copper coat on my other apps.
Old Oct 12, 2007 | 08:39 PM
JPH's Avatar
JPH
who's head bolts are you using? what was your final trq. settings?
Old Oct 13, 2007 | 02:11 AM
xBROKEx's Avatar
yeah just added security, i fired up the car and drove it today, so far so good
xBROKEx's Avatar
ARP studs, torqued to 50, then 80(instead of 75), i retorqued them 3 times before i drove the car.
Old Oct 13, 2007 | 07:10 AM
vettenuts's Avatar
I thought the ARP torque with their lube was 70. Why overtighten? Did you discuss this with ARP first?
Old Oct 13, 2007 | 07:47 AM
I just got some ARP bolts and it says with ARP moly 70 and with 30w oil 85
Old Oct 13, 2007 | 10:12 AM
JPH's Avatar
JPH
great, i go 85 w/oil. you should be good then.
Old Oct 13, 2007 | 11:07 AM
xBROKEx's Avatar
they loosen after the first few heat cycles, just do that from personal experience, never had a problem before.
Old Oct 13, 2007 | 01:24 PM
=ZoomZ='s Avatar
i use 3 coats of copper and when the 3rd coat gets tacky i set them in place and torque 25/50/80 , put 250 miles on the car and retorque to 90.
I did what ARP said ,, once
Then i listened to the old schoolers and never had a problem ever again , and i spray AlOt of nitrous ,, hehe
Old Oct 13, 2007 | 01:29 PM
xBROKEx's Avatar
i also let it sit for a day before i ran the car
Old Oct 13, 2007 | 03:42 PM
=ZoomZ='s Avatar
Yep . i let mine sit over night .
