Dual Valvespring Question
Do I need new seats?
Do I need new retainers?
Do I need new locks?
Do I absolutely have to run new lifters? It says they are recommended but if I pull the heads just for lifters a will more than likely just put on a better set of heads.
Thanks for your help...
Josh
Josh
Valvesprings: AFR 8019
Valvespring Seats: AFR 8042
Valvespring Retainers: AFR 8512
I did valve seals on my heads not to long ago. I'm sure they would be fine staying there. Remember the 98 heads have the seal that is by itself and not attached to the seat or whatever is on the newer heads.
