Using LS2 stuff in an LS1
Old Oct 15, 2007 | 03:00 PM
ROCNDAV's Avatar
Default Using LS2 stuff in an LS1
I've been searching through the archives. I just want to confirm before pressing the "order button".
LS2 Lifter guides (PN 12595365) are priced each, so I must order four, correct? No problems using these in an LS1, correct?
Upgrading to LS2 Timing chain and cam/crank sprockets:
There is no "kit"? I must order the three pieces separately?
If so, the parts are:
12586482 Chain
12556582 Crank Sprocket
????????? Cam Sprocket? (Do I order LS1 cam sprocket or LS2 cam sprocket?)
I don't have either sprocket. When I got rid of the Crankshaft, I left the OEM Sprocket on there since I was getting a new crank and figured I was going with a Rollmaster double roller at the time. I gave the cam gear to someone on here some time ago.
Old Oct 15, 2007 | 03:16 PM
John02Hawk's Avatar
I'm pretty sure that as far as the LS2 chain goes, all you need to order is the chain..
Old Oct 15, 2007 | 03:18 PM
John02Hawk's Avatar
..If not, thunder racing sells the kit as a whole.
Old Oct 15, 2007 | 04:18 PM
ROCNDAV's Avatar
Yeah I need the gears too as I don't have the single chain parts any more.
massls1guy's Avatar
2001 LS1 here. In the middle of H/C swap.
Here are the lifter trays I just installed, you need 4 of them:
http://www.sdparts.com/product/12551...ideLS1LS6.aspx
If you need LS2/LS7 lifters sdparts has a good deal on them as well:
http://www.sdparts.com/product/12499...esSetof16.aspx
I got the 12586482 LS2 chain from thunder racing.
I left the crank sprocket alone. My cam sprocket had a few cracks so I got a new one from the dealer. It's the LS2 design, solid piece (no holes): 12576407.
I wanted a new gasket for the cam retainer plate. The plate and gasket come together (only $21): 12556437.
The new retainer plate has counter sunk holes, no clue why. You need 4 new bolts with wider heads if you want to use the new plate: 11515756
Old Oct 15, 2007 | 04:30 PM
ROCNDAV's Avatar
Thanks. I already have the lifters. So I can use the new style cam sprocket will work? Do you have any pics of it?
My block is a 97 Vette block.
Old Oct 15, 2007 | 04:49 PM
massls1guy's Avatar
I don't know if any of my info is the same for a 97 block. I would ask the dealer to be sure.
I didn't take a picture of the new cam gear and I already have the cover on. I just found this though, very cool. Has a ton of pictures of LSx parts listed by part number.
http://enginepartsplus.com/pdf/GEN%20III%20Hardware.pdf
