O-ringed heads?
either way you can use them on a regular block, the ohio boys are using a o-ringed head with stock GM gaskets to get their car down the quarter in 7.90's at 180+
you can run into issues where you blow a head gasket, lose compression, etc etc.
usually o-rings are made for boosted applications, not nitrous. as it allows the heads to sit inside of a groove in the block, and tighten the heads down a bit tighter to create a better seal since theres going to be alot of boost.
i wouldnt buy them if i were you.
Keith
