rumor for aftermarket heads
Old Jun 10, 2003 | 01:23 AM
00z's Avatar
00z
Default rumor for aftermarket heads
my dad was told buy the owner of www.araoengineering.com that it may be possible that they were going to make a four valve head for the ls1's. i was just wondering if there may be a intrest get the ball rolling a little faster. ls1's sweet port design with four valves i couldnt imagin the gains other than
Old Jun 10, 2003 | 05:37 AM
Raughammer's Avatar
D(irecto)r Pepper
Default Re: rumor for aftermarket heads
News to me....
Old Jun 10, 2003 | 06:59 AM
finalymodded's Avatar
how do they make 4 valves per cylinder work on a 2 valve per cylinder vehicle? There is only camshaft. I just can't visualize what is going to be done.
Old Jun 10, 2003 | 07:03 AM
StevieZ's Avatar
It's in the design of the rocker arms. 1 pushrod opens 2 valves.
Old Jun 10, 2003 | 11:00 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'm sure those heads will cost a bazillion dollars.
AFR is supposed to release some heads for us within the next 12 months, I'm not exactly sure on timeframe.
Old Jun 10, 2003 | 11:03 AM
Malicious's Avatar
I've seen some 4 valve heads for LT1's, but LS1's are new to me. I didn't really take the time to look at how the LT1 heads worked with 4 valves, probably be something similar for the LS1's.
Old Jun 10, 2003 | 07:50 PM
00z's Avatar
00z
the guy was actually saying the ls1's would be easier to do due to the way ports are set which means easier to make the cheeper the'll be. i would imagine the cost to be around the 4-5k zone. but with the gains they say with the rest of the heads. it should be around 150-200 hp gain just from heads and most likely tuning of course.
Old Jun 10, 2003 | 08:16 PM
Killer '01 SS's Avatar
Not likely. I don't recall the *few* people that tried the 32-valve Dominion heads on their LT1's getting anywhere near those kind of gains. But then, I'm getting old, and maybe my memory is slipping.
 Michael S. Palmer
Old Jun 10, 2003 | 08:17 PM
SNAXS's Avatar
150-200 hp?!!!! WoW! I like!
Old Jun 10, 2003 | 08:53 PM
MrYenko's Avatar
I cant remember EVER seeing any proof of a running Dominion or Arao 32v LT1 motor...Lots of pics of the parts, and a couple in a car but incomplete, but no proof. Not even any secondhand witnesses, or friends of friends.
Old Jun 10, 2003 | 08:55 PM
Country Boy's Avatar
Senior Member
Only around the $4000 - $5000 zone?! A little expensive if you ask me, then again were paying $3000+ for a ported STOCK head and ~$800 for a set of $200 headers
Old Jun 10, 2003 | 08:58 PM
JF WS6's Avatar
Those heads are kick *** and all, but still using the LS6 intake.... I don't think that the potential of just regular stage II heads have really been tapped being there is no after market intake yet other than the sheetmetal ones that have only a gain in the high RPM range.....
A solid roller stroker motor with the 4 valve heads and a very high flowing intake would make some very killer numbers NA I'd imagine...
Old Jun 10, 2003 | 10:04 PM
00z's Avatar
00z
www.araoengineering.com shows dyno sheets fo what they have done. as for the intake wouldnt i highly ported holley intake be good enough?
Old Jun 10, 2003 | 10:16 PM
1999_SS_M6's Avatar
lol.. 200HP from 32 valve heads? is that the kind of gains you saw from the 2 valve 4.6 mustang to the 4 valve cobra? ( I thought it was more like 260-320)
Anyway... not to be a hater, but my only response is "puff puff pass... puff puff pass..."
Old Jun 10, 2003 | 10:50 PM
JimMueller's Avatar
I was sent the product literature when they were doing business as Dominion. . All the literature and graphs look the same as 5-6 years ago. I contacted them about 3 years ago and they said they had no plans for a 32v LS1 head. They use forked rockers. (Un)Fortunately(?) my 4l60e gave up the ghost and I moved on to a LS1.
I have a 48s soundclip of a blown 383ci 32v LT1 idling, but nowhere to host it. It's about 1M in size.
Old Jun 10, 2003 | 11:54 PM
00z's Avatar
00z
my dad talked to them about a week ago and he said they had the idea of doing this depending on the intrest but it seems you guys arnt very interested. 1999_SS_M6 were not dealing with mustangs were dealing with pure chevy power so comparing a 4.6 to a ls1 is like comparing apples and oranges. also, it's not a ford or chevy combustion chamber or ford port design used on the arao heads its a totaly diffrent combustion design used with the ls1 port design.
Old Jun 11, 2003 | 12:01 AM
Iv_z28's Avatar
I think oval valves would be a much better idea. I wonder why nobody did it so far..
Old Jun 11, 2003 | 10:21 AM
JF WS6's Avatar
Not really as it's just a cast based on the LS6...... not to mention since it's aluminum it is very prone to heat soak which is why many people don't use it..... The LS6 intake flows like 280 something CFM, while there are already stage II/III ported heads that flow well over 320 for the LS1/6 engine....... I'm sure these 4 valve heads would flow even better, but being that the LS6 intake is only flowing 280 something CFM that's the real bottleneck. If there was an intake port matched to these 4 valve heads that could keep up comparably in flow to them then you'd see some real power.... the key to unlocking more power for the LS1 isn't better heads as of right now IMO, the stock head designs are actually very good.....
Old Jun 11, 2003 | 11:34 AM
camaross383's Avatar
my question is were to put the valves? have you looked at the combustion chanbers on an ls1 head, you would have to have four cute little valves jammed into a very small area no way in hell it will flow 200hp better than the current design imho.
Old Jun 11, 2003 | 11:46 AM
Malicious's Avatar
Email it to me, travish@tulsaconnect.com and I'll see if I can convert it to .mp3 and make it a bit smaller and I'll host it
