oil pressure dropped 10lbs
Old Oct 18, 2007 | 09:23 PM
RED2K's Avatar
Default oil pressure dropped 10lbs
Ok I just dropped a 04 ls1 {22k miles}out of a gto in my silverado. I put a comp 220/224 (new) in it. I had oil pressure problem at first because i didnt replace the oring on the pick up tube. I have driven the truck about 25 miles and the oil pressure went from 40 to 30 lbs at idle. It sits at about 750 rpms at idle. If you bump it up to 1000rpm it climbs to about 38lbs. I have a nitrous tune from the old smaller cammed 5.3 in it. It still has the truck intake and 5.3 injectors. It has a bit of pinging under accel. { i think spark knock} I smelt the oil to make sure it isnt dumping too much fuel and maybe thinning the oil. It does have a fuel smell to it but not too bad. Any thoughts would help. Thanks
Old Oct 18, 2007 | 09:28 PM
217zenki's Avatar
Hope it aint the main bearings..
Old Oct 19, 2007 | 08:36 AM
RED2K's Avatar
i hope not as well
Old Oct 19, 2007 | 09:52 AM
Horsepwraddict's Avatar
have you replaced the o-ring and its still doing it?
Old Oct 19, 2007 | 10:04 AM
RED2K's Avatar
yes. and the first day {7 miles of driving with about 15 minutes of idle time} it held 40 lbs
NOw the next day driving 25 miles it wants to idle at 30.
Old Oct 19, 2007 | 10:20 AM
change oils? What kind of filter are you using
Old Oct 19, 2007 | 10:47 AM
RED2K's Avatar
i am using a wix filter. I am using a 5w30 mobile 1
Old Oct 19, 2007 | 11:56 AM
well the filter isn't your problem most likely, if it was a fram i was going to suggest changing it to a wix. 30 isn't really drastically low for idle, unless thats as high as it goes, it just seems weird that it all of a sudden dropped like that.
lemme brainstorm
Old Oct 19, 2007 | 12:21 PM
.........cam plate could be a little loose, loc-tite the screws?
Old Oct 19, 2007 | 12:33 PM
RED2K's Avatar
no loc tite but they were torqued
Old Oct 19, 2007 | 12:41 PM
oange ss's Avatar
if you intend to drive "aggressivley", i would recommend thicker oil.....i use Mobile 0W-40
Old Oct 19, 2007 | 12:50 PM
RED2K's Avatar
oh its just a putt putt pick'em up truck. lol
Old Oct 19, 2007 | 01:28 PM
RE AND CHERYL's Avatar
30psi at idle is fine and about normal. I wouldn't worry about it.
You need to get the correct tune loaded. The 5.3 tune is obviously going to run lean on a 5.7 even before you take the cam into consitteration.
Re'
Old Oct 19, 2007 | 02:47 PM
RED2K's Avatar
it is programmed a tad rich already. But yes it does need to be tuned. My 2001 z28 has 77k and it idles at 40lbs all day long. I am just wondering what caused it to do this all of a sudden.
Old Oct 19, 2007 | 03:08 PM
3.4camaro's Avatar
I would replace the filter. A clogged filter lowered my pressure.
Old Oct 19, 2007 | 03:11 PM
TheLS1Kid's Avatar
Re'
I agree. See how it is after you get it tuned.
Old Oct 19, 2007 | 03:44 PM
RED2K's Avatar
I just talked to Nelson about a new tune so we will see. I know it needs tuned badly but i am worried about the oil pressure dropping all of a sudden. I thank all of you for your input on this.
Old Oct 19, 2007 | 05:00 PM
67Firebird455's Avatar
Hope you get the pressure issue sorted out, and let us know how that ls1 runs after the tune! How do you like that cam btw?
Old Oct 19, 2007 | 10:50 PM
RED2K's Avatar
So far i like it quit a bit. The tranny wants to shift too soon it seems. I should know more after the tune.
Old Oct 20, 2007 | 12:30 AM
tilly's Avatar
Um, did you try replacing the oil sending unit. Did you have to take the intake off of the motor when you did the swap. If so then I would check your sending unit.
