383 stroker, worth it?
Old Oct 23, 2007 | 05:33 AM
Thule's Avatar
Default 383 stroker, worth it?
my lil angry 346.. is just.. not big enough,
like i have mentioned in some posts here i want a big cube block, (LSX/408/402)
but its just to expensive to build another motor when i am not even finished building the 346,
thats why i started thinkin about buying a stroker kit, and some big cam like Trex/ms4/vindicator,
is it worth the 3k it would cost me? i should be around 420ish rwhp N/A on my current H/C/I set up, (stageII ls6's 59cc 226/226cam fast90/90 and more)
Old Oct 23, 2007 | 06:30 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Had a bud with a Rapid Motorsports 383, it wasnt n2o built but he still sprayed it to easy mid 10's no prob. Thats with a th400, 400ish stall on a moser 12 bolt. Quite a fast car.
Old Oct 23, 2007 | 08:36 AM
Michael02hawk's Avatar
I love my little 'ol forged LS6/383 block! Dyno numbers in my sig are outdated, more like 480/450 (estimated) now. Great Hp and lot sof torque.
Select a good head/cam package with your build, tune it right and enjoy it.
Old Oct 23, 2007 | 08:39 AM
PewterZ28's Avatar
You'll definitely need a bigger cam that is designed for the bigger cubes. That's what I recently found out when I bumped up to a 383 stroker but kept the same cam.
Old Oct 23, 2007 | 09:22 AM
dmiz0420's Avatar
420 rwhp is awefully low for a 383. Aim higher, if you dont get at least 500 rwhp out of it there's a problem...
good rule of thumb is 1.5 hp/ci, if you can't get that your not trying.
If your 346 made 475 rwhp would you still spend $2-$3k on a stroker assembly?
Old Oct 23, 2007 | 10:30 AM
Well - I dont completely agree, or did you mean to say flywheel hp instead of rwhp? Either way, everyone has their own set of goals.
For me, low/mid range power outweighed the peak numbers.
I also wanted a combination that would be a decent daily driver, of course that is subjective too.
Old Oct 23, 2007 | 11:26 AM
Thule's Avatar
i got a 226/226 585 112LSA cam in my motor now,
the 420rwhp is around what i am making at the moment, and for me that is just not enough,
thas why i was thinking about a stroker kit,
isin't the ms4 big enough for a stroked motor? or should i go bigger?
what amount of cain could i expect?
thanks all
Old Oct 23, 2007 | 12:58 PM
Last year I had been running the TR224/114 cam in my 383 with AFR 205 heads. I was putting down 425rwhp. It was fun...but I agree, it wasnt enough.
My winter project was to upgrade the cam. I called Tony Mamo with AFR, and he suggested their 234/238 cam, I choice to keep the 114lsa.
With an updated tune...well, you see my numbers. I'm happy with the setup now. Sure, I still could have gone with a larger cam, since my pistons already have reliefs in them, we even measured clearance, and I do have some to spare. I think my next project would be do get the heads milled.
Old Oct 23, 2007 | 01:15 PM
Bryan @ Speed Inc.'s Avatar
you should get a cam that is designed for a bigger cubed motor, not just grab a popular big cam that's made as a max effort cam-only 346.
speed inc has quite a few stroker grinds. their SS2 cam is a very street friendly cam that has made impressive horsepower/tq.
http://www.ls1speed.com/catagory.cfm...in%20/%20Heads
Old Oct 23, 2007 | 01:20 PM
GMmexican's Avatar
go with a custom stroker grind, its not worth it IMO using a cam desgined for 346ci....your not getting the most out of the extra cubic inches
Old Oct 24, 2007 | 06:06 AM
Thule's Avatar
part of the reason for i want to do this is that i want to reuse my patriot stageII ls6 heads, 59cc, they should be good with the stroker kit?
how much has to bore the cylinderblock for the 383 kit?
Old Oct 24, 2007 | 12:08 PM
CodeRed2000SS's Avatar
i got a ms4 in mine, put down 450 at the wheels, with 5.3 heads
Old Oct 24, 2007 | 12:22 PM
edcmat-l1's Avatar
383, AFR205s, Fast 90, pretty mild cam. Something like a 239/243 .615 on a 113+3.
Its all in the heads, cam choice, and of course the tune.
This was also with a road race safe 12.6:1 or so, and 26 degrees of timing up top.
Old Oct 24, 2007 | 03:34 PM
chrisdacarnut's Avatar
That afr is nice and flat!
Old Oct 24, 2007 | 04:17 PM
LS7jUnKiE's Avatar
a honing is needed to 3.905 inches, the main increase is in the stroke bumping it up to 4.00 inches.
im pretty sure if you dont hone the bore then you end up with 382ci.
Old Oct 24, 2007 | 05:53 PM
Thule's Avatar
interesting!
i want an lsx block.. its just so damn expensive, maybe this is it for me
Old Oct 24, 2007 | 08:18 PM
McLeod's Avatar
That graph looks familiar. I think I know that guy.
Old Oct 24, 2007 | 10:28 PM
Goldfinger911's Avatar
You are exactly correct. ( I think)
Actually, according to Cartek, even with the 3.905 hone, you are at 382ci with a 4" stroke? They have a 383 offering that is a larger bore and shirter stroke. (Does anyone know for sure?)
Either way, a 383/382 is a great 500whp package +/-. Killer midrange and top end too. My car had the worlds worse tune and did close to 500whp. Specs are in sig.
Old Oct 24, 2007 | 10:52 PM
Websy21's Avatar
Like the above states, get a 383 built and cam/heads matched. If you got the dough for some nice heads and fast 90/90 port matched 500rwhp would be no prob and nothing to sneeze at. They are torque monsters too, I've always wanted a 383 on the other hand I am getting a 408 built right now
Old Oct 24, 2007 | 11:02 PM
JRracing's Avatar
A 383 stroker kit is a 3.905 piston, 6.125 rod and 4.00" crank. I have a 383 kit I just bought.
